It is currently Wed Oct 08, 2025 3:01 am
PostPosted: Mon Nov 23, 2009 9:38 am
Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner
High,
1997 Bonneville SE
I need to know the termination points of the (3) ground wires.
There is one approx 10g that comes off the neg battery and connects to the fender. At that location (3) approx 16g ground wires route into a plastic flex harness.
Those (3) wires, where are they routed too?
I'd like to re-terminate those connections as I experienced a split second loss of electrical power while driving.
Thanks for any help.
Bob
PostPosted: Mon Nov 23, 2009 9:48 am
Year and Trim: 2004 Volvo S60
If you experienced a split-second loss of power while driving, I'd really take those battery terminals off and check those if you haven't already...they are a very good candidate for that, and since two dissimilar metals are touching there...corrode quite often.
PostPosted: Mon Nov 23, 2009 10:30 am
Year and Trim: before cars
And check the ground splice packs under the carpet next to each front door.
PostPosted: Mon Nov 23, 2009 11:38 am
Original Owner
Please be more specific: Under the carpet on the 1) floor board 2) firewall or 3) fender kick plate.
thanks for the fast replies
PostPosted: Mon Nov 23, 2009 12:34 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
PostPosted: Mon Nov 23, 2009 2:19 pm
Yeah, that one. ^^^^
And there is one on the the other side of the car in the same spot.
PostPosted: Tue Nov 24, 2009 10:15 am
Original Owner
Again, much thanks. I will clean the battery terminals and apply dielectric grease to the contact area/threads. Clean the fender wall contacts and check continuity at the two ground bus bars under both carpets.
Are there any locations on the exterior underside of vehicle chassis that may also need to be checked? My vehicle having spent its whole life in the North East has plenty of rust under there.
PostPosted: Mon Nov 30, 2009 11:25 pm
Year and Trim: 2012 Eco
Check the engine grounds bolted onto the fenders for corrosion. The ones on my Buick were pretty bad. Cleaning them up made a bit of difference in how the car ran.
There are no new unread posts for this topic. The little wire on the battery ground?
JoeK
Sun Apr 29, 2012 1:55 am
JoeK View the latest post
There are no new unread posts for this topic. engine ground and wire routing
hj2010
Wed Sep 26, 2012 7:51 pm
There are no new unread posts for this topic. Attachment(s) Common wire, ground, plug, or module - issues on 02 SE.
crash93ssei
15
8924
Thu May 01, 2014 11:36 pm
There are no new unread posts for this topic. 1997 Bonneville SE- ground bus issue
edarr
Fri Dec 06, 2013 10:11 pm
edarr
Wed Dec 04, 2013 1:56 pm
edarr View the latest post
