It is currently Tue Apr 16, 2024 2:58 pm
 Post subject: Painting Advice
PostPosted: Mon Oct 27, 2008 8:53 pm
Year and Trim: 2006 Buick Lacrosse CXS
On my 2001 Park Avenue. There are two body colored plastic strips that run the length of the roof on both sides. The paint is fading very badly on these two pieces of plastic. The paint job on the rest of the car is in great shape, except for a ding in a couple of spots. The paint is perfect for the rest of the roof. A shop said he would have to paint the entire roof at a cost of $400. I was thinking of just masking off everything, wet sanding, and painting using some aerosol touch-up paint. I know it won't look the greatest but its on the roof so its not a big deal. But anything would look better than that faded white. (I'll post a pic later). My question is that I am trying to find a good place to by the paint. The paint code is 12 and the color is called Galaxy Silver Metallic. Any suggestions how to do this or where to get some paint for a decent price? The dealer wants $14 for a spray can touch up.
Last edited by white06lacrossecxs on Mon Oct 27, 2008 8:54 pm, edited 1 time in total.
 Post subject: Re: Painting Advice
PostPosted: Mon Oct 27, 2008 9:31 pm
Year and Trim: 1993 SSE
Member since Nov 2003
Do you have access to a paint gun? Air compressor? I highly recommend getting actual color matched paint from your local PPG or DuPont dealer and spraying with a real gun. Harbor Freight has guns starting at $14 that will suit your needs. As always, prep work is key. Make sure to use a premium Dewaxer/degreaser (e.g. PPG Omni MX190 Cleaner or PPG Acryliclean) and then tack cloth before spraying.
1993 SSE Since 11-12-2000
2011 Camaro 2SS
2006 Silverado 3500 4x4
Last edited by John Deere Boy on Mon Oct 27, 2008 9:36 pm, edited 1 time in total.
PostPosted: Tue Oct 28, 2008 10:15 am
Recognized Vendor
Recognized Vendor
Year and Trim: 05 GXP
Unless you can get a spray can at Pepboys or Autozone, or someplace like it.... $14 for a can actually isn't bad. I get my spray paint from a place online, and it's 19-24 a can. Silver is tough to match, and it likely won't match exactly.
http://www.flamingdecals.com
PostPosted: Tue Oct 28, 2008 2:42 pm
Year and Trim: 2001 SE L36
If you go the can route then be sure to go to a shop that can mix the paint by VIN#. GM has slight variations in paint color by year. $14 per can is about right for the good stuff. You will probably need a couple cans. When using spray cans make sure to do MANY light coats. You don't have to wait to long between coats but this will help prevent ripples in the paint. Ie. your first coat should be translucent and hardly cover anything. Build it up until it matches. Also make sure you mask everywhere. Overspray is a pain.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
There are no new unread posts for this topic. Painting the UIM?
Bonnefied_GM
Wed Mar 30, 2011 5:39 pm
Bonnefied_GM View the latest post
There are no new unread posts for this topic. Painting my rims
bs009
Tue Jun 23, 2009 1:28 pm
There are no new unread posts for this topic. vent painting
swampthing
Sat Jan 03, 2009 10:03 am
There are no new unread posts for this topic. Engine painting
Tricked-T
22
3588
Thu Sep 10, 2009 12:02 pm
spydog View the latest post
There are no new unread posts for this topic. Painting the strut bar.
velvetdreams21
25
4029
Thu Jun 05, 2008 1:01 am
