It is currently Mon Mar 17, 2025 7:04 am
PostPosted: Fri Oct 25, 2024 9:51 am
Year and Trim: 2009 Bonneville SE Without Monsoon
So I have an ‘03 Bonnie SE that I recently bought. Finally got the brake line fixed a little while ago and wound up having to have the control arms welded to the cape frame be side they were literally so rusted out they weren’t even connected no more. But the motor’s still solid! Anywho, I’m looking for a custom tail light maker or someone who does tail light repair/mods who can repair and maybe do an LED conversion for my tail lights? I wound up buying a new left tail light cover at the local U-Pull, but definitely needs to be cleaned and repaired before I put it on the Bonnie. And even then, I was wanting to do the LED conversion, whether it be LED strips that are fitted properly for the tail lights (with or without RGB), or actual LED Bulbs (most common). Maybe the LED strips would be better suited for the trunk deck light cover (does that normally glow when you brake on an ‘03? If not, be cool to see it lit up!)
Luckily when I bought my Bonnie, someone converted my low-beams to White LED’s, but left the Highs as yellow Halogen, so might swap that later on down the road.
Also, what other modifications would you guys suggest to do to the Bonnie for not only performance and cosmetics, but for longevity/maintenance, especially if it’s got as much rust as mine does?
I was thinking of what options I have to get more power out of the 3800 Series II motor but it’s very slim for engine mods or even air intake mods because of the age of the Bonnie……….
As for cosmetics for body, I was thinking of trying to fix the bindi rust repair someone did by my gas cap and plastidipping my car with a hyper shift color plastidip to preserve the original color underneath and put a different color on the outside.
2003 Pontiac Bonneville SE in dark red
Modifications made so far (interior-wise):
Aftermarket head unit (Dual XDCPA11BT flashed with Jensen CAR1000BT Firmware)
Backup Camera (still need to figure out how to properly wire this……..help)
Jensen 600w 2-channel Bluetooth Amplifier
2 Kicker CompVR 10” (or maybe 12”) subwoofers currently in the process of being wired in a 4 ohm series-parallel wiring configuration
PostPosted: Sat Oct 26, 2024 10:00 pm
For the lights, I don't think what you want has been done on this board. People swap to GXP lights or cut them apart to remove the colored lens.
Performance wise, nothing is really worth it. Naturally aspirated, you'll never see over 200 whp without a cam. Top swapping is cheaper and easier but still a substantial amount of work for the power.
PostPosted: Sun Jan 05, 2025 2:22 am
Year and Trim: 2000 Pontiac Bonneville SLE Tan on Gold Metallic
you know, im wanting to change my taillights to be a series of strips of LED lights, maybe thats similar to what youre saying?
2000 Pontiac Bonneville SE, Tan on Gold Metallic, 160k miles. Aluminum wheels, vinyl wrap, aftermarket suspension and brakes, full fluid flush and sensor replacement @ 160k. 90% taillight tint, full SSEi sound system swap w/ Pio amp, embroidered floor mats and wooden bead seat covers (for class)
There are no new unread posts for this topic. tail lights
BlackPearlSSEi
12
3227
Mon Aug 05, 2013 11:33 pm
There are no new unread posts for this topic. Tail lights
Bonni
Sun Jun 09, 2019 5:04 pm
96 SSEi View the latest post
There are no new unread posts for this topic. LED TAIL LIGHTS
robjr69
18
5248
Fri Mar 12, 2010 1:17 am
SAMzGXP View the latest post
There are no new unread posts for this topic. Gxp tail lights/ spoiler
Haulin ssei54
Thu Apr 26, 2012 12:56 pm
Haulin ssei54 View the latest post
There are no new unread posts for this topic. Ruby Tail Lights
anwisdom
14
2859
Thu Jul 31, 2008 8:48 pm
willwren View the latest post
