It is currently Wed Jan 23, 2019 9:51 pm
PostPosted: Sat Jun 10, 2017 9:48 pm
RIP 2001 SSEi
I've looked and I've looked and there is almost nothing on this issue besides buying another used trunk reflector. I've got some serious cosmetic issues with my rear reflector. Its de-laminated on all three sides but is fine on the bottom and its let water and dirt in between the reflector and the clear plastic. Im sure everyone here is pretty aware of the problem, every single Bonneville 00-05 I've seen in person had some de-lamination on it. Im wondering if someone has actually managed to take off the clear plastic and clean the thing and reseal it with some sort of clear epoxy or something. I've seen a few people mention it on the GM forums and a thread on this forum and the answer is: Buy a new one! But There are not many out there, and all the ones ive seen for sale are atleast a little de-laminated and expensive. I happen to have an extra one so im going to try anything with that but I'd like to take off the plastic ( you can not pry it off, has to be cut) and clean the inside well and reseal it at the edges preferably with something that dries clear. If anyone has some experience with this let me know, It really looks terrible and detracts from the car. If you guys would like photos let me know I could definitely show you some, though im sure most of you know what it looks like already. I might try to cut the plastic off with a small dremil and cutting disks and reseal it unless someone has any other ideas, and if it goes well I could document the process aswell.
Bonnie - 2001 Bonneville SSEi RIP in spaghetti never forgetti
Goldein - 2000 Bonneville SSEi Live forever.
2.25" I/C, Machined LIM, 42.5 Injectors, 3.0 S/C Pulley, 72mm TB, SD Headers+ZZP DP+magnaflow Catback, ZZP tune.
PostPosted: Sun Jun 11, 2017 10:14 pm
the dremel method should give you good results....... .you be the guinea pig, ok
PostPosted: Sun Jun 11, 2017 11:12 pm
It is a big problem, however not 'every' Bonneville has delamination problems.
PostPosted: Sun Jun 11, 2017 11:30 pm
RIP 2001 SSEi
Hey man, all I'm saying is almost every single one I've seen are...the only one that wasnt I wanted to pry off their car hahaha
PostPosted: Sun Jun 11, 2017 11:36 pm
RIP 2001 SSEi
I suppose I can try it when i get some free time... Any ideas on how to reseal the edges?
PostPosted: Mon Jun 12, 2017 7:46 pm
I would use jb weld and bond it evenly around corners and silicon adhesive( permatex) to keep it water proof.
PostPosted: Tue Jun 13, 2017 3:24 am
So I'd better keep mine locked in the garage then ;)
There are no new unread posts for this topic. Tinting the Reflector
Jatlec26
Mon Oct 21, 2013 12:09 pm
There are no new unread posts for this topic. RCR-Rear Center Reflector
jmal843
Thu Feb 02, 2012 10:16 am
jmal843 View the latest post
There are no new unread posts for this topic. Rear Reflector Brake Lights?
OnlyAnSE
Sat Feb 25, 2012 12:02 am
SLOGXP View the latest post
There are no new unread posts for this topic. Center Reflector Salvage yard find.
kc9dre
Tue Dec 12, 2017 12:58 am
kc9dre View the latest post
There are no new unread posts for this topic. Headlight restoration
*B2*
17
2620
Fri Aug 15, 2008 5:40 pm
*B2* View the latest post
Users browsing this forum: Exabot [Bot] and 1 guest
