It is currently Mon Apr 12, 2021 2:51 am
 Post subject: Don't ever do this...
PostPosted: Thu Feb 12, 2015 4:07 pm
In September of 2013 I purchased a brand new pair of OEM headlamps at a cost of about $1K. I was so pleased with their clean appearance, right up until I saw a small spec of dust inside the driver's side lens. I figured I was being pretty smart by using a can of the pressured air duster with the long nozzle to blow the dust away. Unfortunately, after I reinstalled the bulb and turned my headlamps on it started to smoke inside the housing. The reflective material cracked and became horribly discoloured. I didn't really think that the propellant would do that but I suppose it makes sense.
PostPosted: Thu Feb 12, 2015 4:47 pm
Ouch :( the GXP headlights in my SE have that same cracking too. That chrome is ultra sensitive as well, the slightest touch with even a soft microfiber will scratch it!
PostPosted: Thu Feb 12, 2015 4:49 pm
Year and Trim: 1993 SSE Medium Garnet Red Metallic, Gray
OUCH! That sucks. Thanks for the warning.
I learned a lesson with a tail lamp: Years ago a friend cleaned out a glass driving light with 90% rubbing alcohol, so that is what I used in November. Looked great for about a minute, then the clear outer cover became opaque, and cracked all over. The colored portions of the assembly were completely unaffected! Grrrrrrrr.
Dang.
Alan Sheidler
Proud Third Caretaker of the Family Heirloom '93 SSE
Medium Garnet Red Metallic, Gray Leather Interior
Silver Cross-Lace Wheels (I love this car)
PostPosted: Thu Feb 12, 2015 4:55 pm
The chrome in the GXP lights appears to be much more sensitive. I have a pair of GXP reflector buckets that are absolutely trashed from being exposed to water and heat. The chrome is peeling. The only purpose left for them is if anyone wants a blacked out retrofit… Hahaha
In contrast, I found that the chrome in the normal head lights, while extremely sensitive to touch, can be cleaned without damage with a glasses cleaning cloth and some moisture from your breath.
"Penelope" - 2003 SLE - 218k Miles
"Sydney" - 2000 Honda S2000 - 81k miles
PostPosted: Thu Feb 12, 2015 6:20 pm
So what exactly happened from doing this? Did it break the foil or something causing it to come into contact with a hot bulb? I'm trying to understand how a fire started.
I've given many GM light housings a quick shot from the nozzle on my air compressor (a heck of a lot more powerful than a can of compressed air), over the years and have had zero issues whatsoever.
2003 Chevrolet Suburban 2500: Doeskin Tan - new plow truck
PostPosted: Thu Feb 12, 2015 6:38 pm
Does the canned air leave residue that would cook?
PostPosted: Thu Feb 12, 2015 6:50 pm
Canned air is has some sort of accelerant in the can. That is most likely the culprit.
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Thu Feb 12, 2015 6:57 pm
Ahhh, got it...
PostPosted: Thu Feb 12, 2015 11:01 pm
I thought the air in "canned air" could be used as a refrigerant. If that's true it would be like blowing Freon on the back side of a mirror, wouldn't it? - BC
PostPosted: Fri Apr 02, 2021 12:55 pm
Year and Trim: 2001 sle, 2004 sle, 2002 ssei
Most canned air is nitrous like they use to refill whip cream cans
PostPosted: Sat Apr 03, 2021 5:48 am
Year and Trim: 1987 Oldsmobile Delta 88
1989 Buick Le Sabre
Aerosol cans are normally filled with a propellant that won't react with whatever is to be put in it. For years hydroflourocarbon was used, much like old fashioned freon used in a/c systems. This has been outlawed in most of the world now.
I haven't any idea what is used now.
But anyway, if I see a speck of dust inside my headlamp I think I'll just leave it there.
Roger.
PostPosted: Mon Apr 05, 2021 10:20 am
Year and Trim: 2003 SSEi
I've been looking for dust specks in my headlights since this was first posted back in 2015.
:poke:
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
cron
