It is currently Mon Feb 18, 2019 11:57 am
PostPosted: Sat May 05, 2012 11:47 am
This write up is specifically for wrapping the 2000+ dash vents using 3M 1080 carbon fiber vinyl, but other interior parts on all years as well as different vinyl materials will also be a very similar process.
I ordered a 1'x5' roll of the vinyl from amazon.com for about $21 shipped and I still have a TON of it left, more then enough to do several sets of vents.
Remove the trim bezel from your vent housing, it just pops off. Clean it thoroughly with rubbing alcohol to remove any oils and dirt that may be on it to ensure a good hold for the vinyl.
Lay the bezel on the wrap and cut out a section slightly larger then the overall size of the part you are working on.
Peel the backing off the vinyl and lay the vinyl sticky side up on a flat surface, then lay the part down as centered as possible on the vinyl
Pick the part with the vinyl attached, careful to not touch the sticky area as much as possible. If it is relatively flat you can just slowly work around the outside edges to get the basic area laid out, if it is not very flat use a blow dryer to add a little heat and make it smooth over the outer surface.
I set the blow dryer on high heat, low fan speed on it's side on the edge of the counter to leave both of my hands free to work. Start with the outside edge, pull and stretch the vinyl over the edges, curves are the hardest part as the vinyl will want to wrinkle when going around them, just keep heat on it and pull it tight enough to remove the wrinkles then press and hold the vinyl to the surface until it cools and holds, usually a couple seconds.
Continue your way around the outside and you end up with this.
At this point you can cut little slits inside the area to be drawn into the vent area
Heat it up again and begin to work it down.
When you get to the bottom of the vent area, cut off all but about 1/8" and cut little slits in that all the way to the edge of the vent so you can heat it and bend them over the edge on the back side.
Start on the other side repeating the process, I found that more slits makes it easier to stretch.
Cut a few slits in the vent adjust section, one right down the middle and two on either side by the curved edge to make it fold into the inside easy.
Heat and wrap that around to the inside.
You now have a finished vent bezel.
PostPosted: Sat May 05, 2012 11:53 am
Good tutorial. I will be doing this to the dash trim bezel for my 97. Looks good
PostPosted: Sat May 05, 2012 1:09 pm
Year and Trim: '02 SSEi
Got a lil wrinkle there.
It looks quite good. I may not have a market for real carbon pieces now. lol
PostPosted: Sat May 05, 2012 1:15 pm
Yea, still not 100% perfect, this was only the second one I did :lol: any wrinkles seen here though are completely hidden by the dash, so I wasn't too worried.
PostPosted: Sat May 05, 2012 1:20 pm
Year and Trim: None
Very nice work man. Im not sure I have the patients for that. At least I dont for myself, maybe if someone was paying me to do it.
2004 Saturn Ion 3 Quad Coupe
PostPosted: Sat May 05, 2012 5:28 pm
Good writeup Ryan!
Some may want to paint the grilles and adjustment cones black like a GXP vent, could use Krylon Fusion for that. Easy to use and holds up well. My OCD may get bothered by the gray. Other than that I like em a lot!
92 Bonneville SSE | L67/4T60E | 72K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 188K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 237k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 186k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 141k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
PostPosted: Sat May 05, 2012 7:14 pm
Year and Trim: 2004 Volvo S60
Nicely done!
PostPosted: Sun May 06, 2012 3:45 pm
Online
I'm actually starting to like this better than GXP.
PostPosted: Sun May 06, 2012 6:36 pm
Year and Trim: 2004 GXP
I like them a lot better then GXP vents, they look really nice.
Seth
RogueSSEi wrote:
Bet she'll stop on a dime and give you 3 pennies back!
PostPosted: Sun May 06, 2012 11:03 pm
Year and Trim: '03 SSEi
Yea this is awesome. Way easier and cheaper than hunting down real GXP vents and these look better. And a nice write-up.
Chris
2003 SSEi|Galaxy Silver Metallic
PostPosted: Sun May 06, 2012 11:21 pm
I am glad to see that many of you like this look! I honestly thought I would get a lot of people saying the exact opposite, that they hate this and the GXP looks much better and that this looks cheesy etc...
The vents aren't too terribly hard to do, but wow.... I just got done after about an hour or so working on one door handle bezel! Those are touchy, but wow does it look amazing!
PostPosted: Mon May 07, 2012 12:20 am
Pictures of those somewhere??!! Please!
Seth
PostPosted: Mon May 07, 2012 12:31 am
I know you already seen them and replied, but just in case others are curious as well - viewtopic.php?f=27&t=32634
PostPosted: Mon May 07, 2012 11:14 am
Yea they really look good man. I saw a thread a while back where someone had their GXP vents re-wrapped in carbon fiber and it showed how brown the factory carbon fiber was and how it doesn't really match a gray interior. Might have been Andrew, I don't remember.
Chris
PostPosted: Mon May 07, 2012 12:04 pm
Chris, that was ddadler... ;)
James May wrote:
Hello.
PostPosted: Mon May 07, 2012 12:40 pm
That's right, thanks Will. That's one of those threads you find after cruising all the old posts cause you can't get enough Bonneville.
Chris
PostPosted: Mon May 07, 2012 12:46 pm
One more thing to add, is if you know you've used a lot of Armor-All or something on these, it would not be a bad idea to wash them using Tri-Sodium Phosphate, which you can get at a hardware store. It's a strong cleaner and will pull all the oils, grease, dirt, etc out of the grains of the plastic which can reduce adhesion of the vinyl over time. Even a quick wash in some soapy water would be better than nothing.
Definitely still wipe them down with alcohol before applying, but this is a good intermediate step to insure long-term full adhesion. Also works well if you're painting plastic or vinyl parts.
Just like anything else, the better you prep, the better the end result will be.
PostPosted: Tue May 08, 2012 4:10 pm
1993 Bonneville SSE
Oh yours has an adhesive backing...what I used was actually more of a fabric and I had to use headliner adhesive spray.
Not sure which would be easier...I'm sure there's some pros/cons to both.
I need to finish/redo what I've done so far.
But in any case, nice work Ryan, as always!
'93 SSE "Guinevere" Mods: Intense FWI | 180º T-Stat | Flowmaster 80 | Magnaflow Cat | Projector Fogs | Clear Corners | ES Poly End Links
Achievements: Guinevere - 264k mi | 16.27 @ 84.10mph | March '11 COTM :: Chloe - 223k mi | 13.85 @ 102mph | January '09 COTM
Last edited by WhiteArrow3800 on Tue May 08, 2012 4:10 pm, edited 1 time in total.
PostPosted: Tue May 08, 2012 4:27 pm
One more thing to add, is if you know you've used a lot of Armor-All or something on these, it would not be a bad idea to wash them using Tri-Sodium Phosphate.
That's one way, but I used paint thinner on everything I painted, it worked great. Paint thinner, not mineral spirits though, a lot of people mistake the two. (Years of retail hardware experience speaking.)
James May wrote:
Hello.
PostPosted: Sun May 13, 2012 3:13 pm
Clean it with alcohol and put primer 94 on the edges. The natural tendency for this vinyl is to straighten in the heat. All those compound corners are going to lift in the heat.
There are no new unread posts for this topic. Wrapping dashboard or whatever ideas
wpbrink
Tue Feb 06, 2018 9:04 pm
There are no new unread posts for this topic. 3M Carbon Fiber Vinyl Wrap VS "Black Metro 3D vinyl wrap"
1oldman
Tue Feb 10, 2015 7:29 pm
There are no new unread posts for this topic. Headliner Replacement Tutorial
Sun Aug 27, 2017 12:05 pm
redfury View the latest post
There are no new unread posts for this topic. '00+ Clear Corners (pic by pic tutorial) 56k beware
TrueWildMan
Sat May 24, 2008 7:48 pm
TrueWildMan View the latest post
There are no new unread posts for this topic. Zaino Z10 on vinyl?
LeSabreUltra
Mon Apr 05, 2010 5:31 pm
tripscarcare95 View the latest post
