It is currently Tue Dec 11, 2018 2:19 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed May 14, 2014 10:43 pm
Year and Trim: 2001 SE
one of my doors window molding is split and you can see the metal beneath. do i just use something to try and cut it and get all the black off then vinyl it?
PostPosted: Thu May 29, 2014 11:28 am
why not try body filler first, then sand it smooth the put the vinyl on.
PostPosted: Sat Jun 21, 2014 6:39 pm
Year and Trim: 2000 SE
I just did this today. It turned out OK. I used a pretty cheap vinyl.
I had the peeling & rusting issue on the driver side trim. Only the part under the mirror was still intact. It would have been a very long process to use filler, so I used a razor knife to cut the rubber/plastic down until it was even with the metal for the most part. Of course you have to use sandpaper, vinegar and/or baking soda accordingly to remove the rust and smooth the surface. The surface & bumps you see before laying the vinyl will all be apparent so make it smooth. Make sure to cover all of the metal to hopefully protect the thing from rusting again.
Some of the vertical trim is starting to come off slightly, that will be my next target.
2000 Dark Bronzemist Pontiac Bonneville SE 3800 Series II L36
1998 Bright Arctic White Chevrolet Lumina LS 3100 Generation III L82
PostPosted: Mon Jun 23, 2014 12:07 am
If you want to stay OEM, I sell the vertical trim in excellent shape for $20 each or $50/set of 4.
-Andrew-
PostPosted: Sun May 03, 2015 7:19 pm
Year and Trim: 2001 SSEi
That is exactly what I was hoping to find. Thanks for the post and link
PostPosted: Fri Apr 29, 2016 1:14 pm
Year and Trim: 2000 Bonneville SE
Jim and Andrew that looks great, i have some wasted ones so i decided to go blue carbon fiber (just to add a little color to the silver), did the shirter plate too....Image
1967 Firebird 400 (stock looking but not)
2000 Bonnevile SE (plain)
2004 Grand Prix GT (mildly modded)
PostPosted: Mon Jul 04, 2016 1:12 am
Year and Trim: 2002 se
i need the inside window trim, i cant find it anywhere and i was hoping you guys could possibly steer me in the right direction?
There are no new unread posts for this topic. Window Molding Kit
EWC88
Mon Jul 29, 2013 6:11 pm
rmccall869 View the latest post
There are no new unread posts for this topic. Door/Window molding needs replacing
Noah.Dreams
Sat Jun 28, 2008 9:17 pm
There are no new unread posts for this topic. 92 Bonne molding
cinzy0
Mon Aug 21, 2017 5:12 pm
cinzy0 View the latest post
There are no new unread posts for this topic. Side molding care
Tue May 04, 2010 11:17 am
There are no new unread posts for this topic. Body side molding coming off?
jstorm1140
Mon Apr 13, 2009 8:06 pm
jstorm1140 View the latest post
