It is currently Fri Mar 05, 2021 5:49 pm
 Post subject: SE to SSE Trim Swap
PostPosted: Thu Jan 13, 2011 6:46 pm
Due to the fact that I dislike the exterior SE trim with the crappy chrome strip. I have decided to fully swap my exterior door trim for the SSE trim. I wanted to know if this is plug and play. I know the SSE trim covers the full lower half of the door compared to the SE only covering a section of the door. I already have an SSE front bumper and grille on the car and I have the rear bumper sitting in my garage waiting to get put on. I also intend on getting a true dual system on this car. I plan on running 2 Flowmaster Super 44's with dual outlets. I am mainly gettting these cause they make my car sound like a beast. Give e your thoughts for this project. Picutres of the front bumper and grille are on their way soon.
Last edited by PLAGUE PHANTOM on Thu Jan 13, 2011 6:47 pm, edited 1 time in total.
 Post subject: Re: SE to SSE Trim Swap
PostPosted: Thu Jan 13, 2011 9:21 pm
I agree with the super 44's. I have them on my 01 and I also had them on my 06 impala 3.9 V6. The Bonnie sets off over sensitive car alarms and the Impala sounded like a V8 at idle. (As close as it could anyway...)
FWIW, the bonneville has a stock exhaust except for the mufflers. The Impala was stock except for the mufflers and the resonator was removed ;)
Also, I think your swap will look good. Looking forward to pictures
91 Buick Riviera | S2 L67 swap/4T60E | 124k mi | Antelope Beige Metallic w/Tan Int | Beat-up Beater / Cool Digital Dash
92 Pontiac Bonneville SSE | L67/4T60E | 75K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule / Storage Occupant
92 Chevy Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Rusty Storage Occupant
03 Buick Park Avenue Ultra | L67/4T65E-HD | 197K | White Diamond Metallic w/Shale Int. | Rust Free Southern Sourced Storage Occupant
99 Chevy Tahoe LT | L31/4L65E | 246k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig / Tow Pig / Portable Concert Hall
04 Cadillac Seville STS | L37/4T80E | 216k mi | Red Jewel Tintcoat w/Shale Int. | Storage Occupant Too
05 Cadillac Deville | LD8/4T80E | 146k mi | Black w/Two Tone Tan Int. | Livery Pkg Daily
James May wrote:
Hello.
PostPosted: Thu Jan 13, 2011 11:02 pm
I know it will look good but will it work like plug in play???
PostPosted: Thu Jan 13, 2011 11:14 pm
Moved to the proper section (this isn't a mechanical problem, so it belongs here)
PostPosted: Thu Jan 13, 2011 11:18 pm
my bad...still getting used to this forum thing. :offtopic: lol...but i hope someone answeres my question
PostPosted: Thu Jan 13, 2011 11:30 pm
The SSE cladding is held on by clips, which are in turn held in by studs that were spot-welded to the doors at the factory. Fairly certain the studs on the SEs are in different locations than on the SSE/SSEi models.
BonneMe wrote:
PostPosted: Thu Jan 13, 2011 11:59 pm
They are. Door cladding would have to be done with adhesive. And the conversion looks lame without it. In addition, the rocker panels are also different. So it's all 4 door cladding pieces, front and rear bumpers AND supports, and rocker panels.
PostPosted: Fri Jan 14, 2011 4:15 pm
Year and Trim: 2000 Pontiac Bonneville SE
I doubt that a true dual system is even possible.
1993 Buick Regal GS Coupe
PostPosted: Fri Jan 14, 2011 6:51 pm
A true dual setup (one pipe from each bank of cylinders) is not possible with how our exhaust is setup, or at least not worth it. I'd do like the stock SSEi's do it, split it towards the rear and into 2 mufflers.
PostPosted: Fri Jan 14, 2011 7:02 pm
True duals is very possible. I fit 3 primaries and a crossover between the exhaust tunnel and p/s rack under the car.
But, IMO it's not worth the trouble.
PostPosted: Fri Jan 14, 2011 7:26 pm
I agree. True dual exhaust is VERY possible, but not worth the time or money for the minimal gain it would get you.
PostPosted: Fri Jan 14, 2011 8:27 pm
my bad. however the SSEi has it set up is how i will do it. Still sticking with the 44's. How will the trim go on and will it cover the original cladding from my SE
PostPosted: Fri Jan 14, 2011 9:11 pm
I believe you would need an 80 series muffler.
PostPosted: Fri Jan 14, 2011 9:16 pm
PostPosted: Fri Jan 14, 2011 11:07 pm
my friend uses a Super 44 for his SE. I plan on doing the same just with a dual exhaust format.
PostPosted: Fri Jan 14, 2011 11:42 pm
That's the thing...you CAN'T. You only have one exhaust pipe entering the transverse muffler, with two exits, one on each side. You can only use 1 44, but only one outlet, which would put it on the passenger side.
And....even if you "y" pipe it, there is no room to longitudaly (spelling?) mount one muffler, let alone two (and one of those two sides will have your air pump for the rear shocks, which knocks your idea out even more).
If you want sound, you HAVE to use a transverse muffler.
PostPosted: Fri Jan 14, 2011 11:51 pm
i get where your going now... #-o
PostPosted: Tue Jan 25, 2011 3:46 pm
Still need to know if the SSe trim will cover the SE trim door cladding. :dontknow:
PostPosted: Wed Jan 26, 2011 9:57 am
Anybody know....
PostPosted: Wed Jan 26, 2011 11:14 am
The answer was already given by sandrock and willwren in this thread.
-Andrew-
There are no new unread posts for this topic. SE trim
bonnevillain
Thu Jun 05, 2008 6:10 pm
Night Crawler View the latest post
There are no new unread posts for this topic. interior trim
wast3dd3ath
Sun Aug 23, 2015 12:04 am
There are no new unread posts for this topic. Sunroof trim
Tlpin90
Mon Jan 18, 2016 5:49 pm
Tlpin90 View the latest post
There are no new unread posts for this topic. Window trim
drdoo55
Tue Jan 18, 2011 11:56 am
There are no new unread posts for this topic. chrome trim on an SE
psburtis
Sun Jun 01, 2008 3:02 pm
psburtis View the latest post
