It is currently Wed Dec 19, 2018 9:39 am
 Post subject: removing door panel
PostPosted: Sat Oct 09, 2010 1:10 pm
Year and Trim: 95 bonneville SE
I got some new mirrors to put on my car, but I cant figure out how to take the door panel off. does anybody know how to take it off a 95 SE
 Post subject: Re: removing door panel
PostPosted: Sat Oct 09, 2010 1:15 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
search is your friend, don't be afraid of it
viewtopic.php?f=19&t=20030&hilit=remove+door
PostPosted: Sat Oct 09, 2010 1:18 pm
Pop the whole courtesy light out. Be very careful, they break. I use a small flat blade screw driver on the rear end first.
Remove the two or three screws along the bottom and up the front.
There's a screw behild the pop-out plate behind the release handle.
There might be one behind the mirror control... can't remember.
The the panel will be hanging by the top edge. Can't remember the best way to pull that off. Up and carefully probably.
PostPosted: Sat Oct 09, 2010 1:27 pm
my apologies........95 :spanka:
PostPosted: Sat Oct 09, 2010 2:43 pm
well thanks for the help, I got it off but it looks like its gonna be a pain to get the old mirror off and the new one on.
PostPosted: Sat Oct 09, 2010 3:02 pm
yep, you have to shove your arm way up in there and operate a 10mm wrench or socket to remove 2 nuts. and operate means tiny turns of the nut. slow and steady wins the race though.
PostPosted: Sat Oct 09, 2010 9:29 pm
ya its not gonna be easy, at least now i know what size wrench i need. and now i know how to take the door panel off for some future mods i have in mind.
PostPosted: Wed Oct 13, 2010 1:12 pm
Year and Trim: 96 SSEi- 157K
I have replaced several of those and never been able to get even a small ratchet/ socket in there, it will only work for the easier nut.... Sears i believe sells ratcheting wrenches singly, getting the mirror out and back in is SOOO easy if you have one.
- Rachael
PostPosted: Wed Oct 13, 2010 1:21 pm
A ratcheting box end wrench would be the best tool for this job. I've done it to with a normal open ended wrench, and it was a pain.
PostPosted: Thu Oct 14, 2010 7:26 am
well i was able to get a ratchet up there no problem and get both of them off, my arm hurt after i did it, but i got it done.
PostPosted: Thu Oct 03, 2013 7:05 am
SUCCESS!!!
There are no new unread posts for this topic. removing trunk connector from trim panel for air
jet020
Thu Oct 03, 2013 7:48 pm
jet020 View the latest post
There are no new unread posts for this topic. Removing all vents and door handles/inserts
xyeLz
Fri Mar 14, 2014 9:20 am
MurderMitten View the latest post
There are no new unread posts for this topic. Adding Door Panel Courtesy Lighting - 2001+ Bonneville
ddalder
Fri Dec 11, 2015 11:31 pm
ddalder View the latest post
This topic is locked, you cannot edit posts or make further replies. removing swirls
bonnevillain
Fri Oct 04, 2013 5:50 am
There are no new unread posts for this topic. removing badges
blackbeauty00
Sat Nov 20, 2010 2:21 pm
SLEighride03 View the latest post
