It is currently Sun Feb 17, 2019 10:39 am
PostPosted: Thu Mar 18, 2010 11:11 pm
Year and Trim: 1994 Pontiac Bonneville SSEi
I have the 1994 and the paint issues that many of those had as well. I'm dealing with the roof paint, but I don't know how to take care of the peeling paint across the plastic rear bumper piece... It's obviously got all those ridges that the Bonnevilles have, and it's plastic as well, so I assume I wouldn't be able to just take a sanding block to it.
Some parts of the bumper have the paint peeled entirely off (but its still a muted black color), but other parts are still covered and flaking. Any advice on removing that peeling paint?
Thanks.
1994 Pontiac Bonneville SSEi; CAI; Hood vents; SE grille; LED mirror turn signals; LED running lights (wired to fogs);
Garage:1999 Nissan Maxima SE, stock; 2003 Chevrolet Suburban LS, K&N filtercharger;
PostPosted: Thu Mar 18, 2010 11:15 pm
Year and Trim: 2000 SLE - Black
A paint remover is made specifically for plastic body panels. However, I usually just hand sand until I can't hand sand anymore. You have a lot of control and a good feel for the strengths and weaknesses of the piece you're working on. Therefore, they usually turn out a bit better. See what a good 180 grit paper does and go from there. If it is going well, follow up with a high build urethane primer to fill the sanding scratches and finish it off with a smooth 600 grit wetsand.
Black 2000 SLE
PostPosted: Fri Mar 19, 2010 10:09 am
180 is going to be a bit too aggressive on a plastic bumper. You don't need the scratches in the plastic. Otherwise, I agree. Wet-sand to feather the edges back until you find where the paint still binds.
PostPosted: Fri Mar 19, 2010 10:49 pm
Thank you sirs!
There are no new unread posts for this topic. Buffer Job On Rear Bumper Cover Spidered Paint!!
Rick1488
Wed May 30, 2012 7:51 pm
Rick1488 View the latest post
There are no new unread posts for this topic. Front Bumper Paint Issue
PontiacFan
Mon Dec 27, 2010 1:32 pm
zigger21 View the latest post
There are no new unread posts for this topic. Rear Bumper
Rapp16
Wed Jan 13, 2010 5:10 pm
Rapp16 View the latest post
There are no new unread posts for this topic. 1999 SLE rear bumper sag
99bonnie
Tue Jul 28, 2009 5:24 pm
99bonnie View the latest post
There are no new unread posts for this topic. Rear bumper removal
psburtis
Tue Feb 01, 2011 9:26 pm
psburtis View the latest post
