It is currently Mon Feb 17, 2020 8:19 pm
Post new topic Reply to topic  [ 19 posts ]
 Post subject: LED TAIL LIGHTS
PostPosted: Fri Mar 05, 2010 10:23 pm
Year and Trim: 1996 Pontiac Bonneville SE
Does anyone know where or if they sell LED tail light assemblies for 05 Bonneville. I only seem to find Grand Prix or Grand Am. I guess they dont think people fix up Bonnevilles.
 Post subject: Re: LED TAIL LIGHTS
PostPosted: Fri Mar 05, 2010 10:27 pm
I haven't seen any. I'm sure there's places that will make them for you, though. I know there's lots of places that do things like halos and LED strips.
PostPosted: Fri Mar 05, 2010 10:29 pm
I wish I knew where i could have them made.
PostPosted: Fri Mar 05, 2010 10:32 pm
:lol: Well, I'd give you some links if I had any experience myself with them. Google is your friend.
PostPosted: Sat Mar 06, 2010 1:33 am
Year and Trim: Member since Jan 2003
You could probably jsut replace them with LED bulbs...
(Nice avatar btw :wink: )
-driverjohn2005
"Gravenge" -1992 Pontiac Bonneville SSEi- Sold 4/29/12 to "myfirstbonnie"
Current Rides: 2015 Mitsubishi Outlander Sport GT AWD & 1999 Ford F-150 Lariat 4x4 SuperCab
PostPosted: Sat Mar 06, 2010 1:37 am
I went ahead and ordered the bulbs. I ordered 4 with 48 leds on each for the parking and brake lights. I want to get for the signal lights but I dont want them to flash fast. I heard you have to change the flasher to fix that but it seems the flasher is built in with the hazard switch so I dont know if i will be able to do that or not. I need to get white leds for the reverse lights too.
PostPosted: Sat Mar 06, 2010 1:51 am
Yeah, LEDs will not work in the flashers without modification. The normal bulbs use resistance to help time the flashes, and LEDs don't have that resistance.
PostPosted: Sat Mar 06, 2010 1:53 am
Does a 00+ have a flasher or is it controlled by a module where the resistance wouldn't matter?
PostPosted: Sat Mar 06, 2010 1:54 am
good question.. come to think of it I just assumed.
PostPosted: Sat Mar 06, 2010 2:30 am
Check out hidplanet.com, they have an LED section with plenty of people who have redone their taillights and can help you along the way.
-Dan
_
_
PostPosted: Sat Mar 06, 2010 3:12 am
Year and Trim: 2003 SLE || 51k miles
Some LED bulbs have built in resistor circuits to stop the fast-flash issue.
-Mike
PostPosted: Sat Mar 06, 2010 2:25 pm
Year and Trim: '02 SSEi
The PnP led bulbs wont give you the look youre looking for and tend to fall quite short of filiment bulbs in performance.
PostPosted: Sat Mar 06, 2010 11:21 pm
I ordered LED dome lights too. Im going to get the backup and turn signals also. I am going to buy an LED flasher so they will work...does anyone know where the signal light flasher is?
PostPosted: Sat Mar 06, 2010 11:40 pm
Year and Trim: 2004 Volvo S60
Replacing standard halogen tail-lamps with LED is NOT going to be a very good idea, if you notice any car with LED's has specific reflectors around them that work differently than your standard far set back reflector...in other words it'll be very dim and ineffective. I've tried this with some of the best LED replacements on the market, they never come out nearly as bright. You'd have to gut the tail-lamp assembly and modify it to have proper reflectors. The only thing I could ever come up with otherwise is the giant LED boards sold on autolumination:
as such lined right against exterior.
Last edited by ChilinMichael on Sat Mar 06, 2010 11:40 pm, edited 1 time in total.
PostPosted: Sat Mar 06, 2010 11:55 pm
nevermind..I found it.. the flasher is built in with the hazard switch
PostPosted: Sun Mar 07, 2010 5:33 pm
If you want LED bulbs to replace your stock bulbs, this company is one of the best out there, but you have to pay to play. http://www.v-leds.com/
PostPosted: Sun Mar 07, 2010 11:19 pm
hello rob
yes the flasher is built into the switch
my GXP have full leds and i used a load equalizer to fix the problem
i have red turn signals in the back
http://www.v-leds.com/Exterior-LED/Brak ... 70633.html
and switch backs in the fronts
http://www.v-leds.com/Exterior-LED/Turn ... 72045.html
as for the brake lights
i might grab a set of those
http://www.v-leds.com/Exterior-LED/Brak ... 72879.html
Cardomain link
Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
PostPosted: Fri Mar 12, 2010 1:06 am
Year and Trim: 2001 SSEi
This is interesting.
I remember back in the day, aka a year ago, I bought myself about $150 worth of LEDs from autolumination for my 01 SSEi and man... problems would be an UNDERSTATEMENT. First off, I'm not sure exactly what I bought, but there are a lot of bulbs in there.
First of all, we have our taillights which are each a bulb. Then we got our turn signals. Then we have these extra little warning bulb things... I don't know what they're called. I also got reverse lights. So I got an LED for each bulb.
It looked great... the delay from hitting the brake was very noticeable compared to standard bulbs. Only thing was, it started screwing my systems up. First, my traction control wouldn't stay on. Next, my AB light came on. Took it to the dealer and it was some type of short caused by the lights... according to them. I completely disagreed but I have no idea ^_^. So I took them out for a while (but I left the reverse lights in there). Still haven't messed with them since then but that was a $1,200 system in my car I had to replace so I don't really want to do it again haha.
I MAY try the V-LEDs and see how they work... if that doesn't mess with anything, that would be GREAT. And I don't have LED turn signals so that would be even more fantastic!
Anyone have my issues before?
Black 2001 SSEi | Performance: INTENSE FWI, INTENSE Shift Kit, INTENSE 180* Thermostat, GXP Calipers (custom powder coated), EBC GD Sport Drilled and Slotted Rotors, EBC Redstuff Brake Pads Aesthetic: Debadged | Cleared Front and Rear Corners | Red Rear Turn Signals | Bright White LED Reverse Lights | Black Centerpiece | Black Pontiac Emblem | 35% Huper Optik Tint | GXP Interior (Carbon Fiber Vents and Handle Inserts, Stainless Handles, Shifter, Black Buttons for Windows and Cockpit, Cupholders) | Hood and Rear Quarterpanel Herpes :thumbdown:
PostPosted: Fri Mar 12, 2010 1:17 am
my car have FULL led conversation all over the place.. and i never had a problem
i tried both autolumination and V-LEDs... V-LEDs FTW
Cardomain link
There are no new unread posts for this topic. Tail lights
Bonni
Sun Jun 09, 2019 5:04 pm
96 SSEi View the latest post
There are no new unread posts for this topic. tail lights
BlackPearlSSEi
12
1982
Mon Aug 05, 2013 11:33 pm
There are no new unread posts for this topic. Tinting the tail lights...
LUVMYBONN
Fri Sep 26, 2008 10:25 pm
Ragsdale View the latest post
There are no new unread posts for this topic. Gxp tail lights/ spoiler
Haulin ssei54
Thu Apr 26, 2012 12:56 pm
Haulin ssei54 View the latest post
There are no new unread posts for this topic. Trouble getting tail, lights or otherwise.
radomirthegreat
Thu Jan 15, 2009 8:04 pm
Peterg22000 View the latest post
