It is currently Tue Jan 22, 2019 2:56 am
 Post subject: Leather seat skins
PostPosted: Thu Apr 30, 2009 8:25 am
Year and Trim: 95 SSEi
05 GXP
Is it hard for an amateur to change the bottom leather skin on a seat and do
a good job. It appears you can buy the skins for $250 on ebay or $325 from
the dealer. The dealer also sells the foam underneath but I didn't ask the price.
Is new foam a good idea also?
If it's hard to get good results, or takes all weekend, there is a company in St. Louis
that does it, but they aren't cheap.
I'm just looking for input before I pull the trigger on a skin. My Tahoe and SSEi need it bad now, and I know the GXP suede will need it in the future.
Black 95 SSEi (original owner) 236K miles
Black 05 GXP (some idiot put the first 12K on it)165K miles
Black 04 Tahoe (original owner)284K miles
Black 16 Traverse (original owner)48K miles
Black 15 Lacrosse (some nice lady put first 15K on it)16K miles
 Post subject: Re: Leather seat skins
PostPosted: Thu Apr 30, 2009 4:18 pm
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
It shouldnt be to hard, but you might have to remove the seat out of the car. That should be the hardest part. & if it has the bottom clips, then you have to buy the tool to remove them & install them.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
PostPosted: Fri May 01, 2009 1:42 am
I buy seats from junkyards in good shape and swap out the parts. You will need a good pair of diagonal cutters (I use 8" Klein cutters) a pair of hog ring pliers and a good supply of hog rings to do the work. Go to a good upholstery shop; tell them what you are working on, and they will sell you the correct size tool and rings.
The work is tedious, and you must be reasonably careful, but the end result is worth it. I am doing the very same thing for an old Lexus I am restoring. I have done a lot of seats, and it took me maybe 40 minutes to remove the seat back leather that I will be swapping out.
A good junkyard seat is a much better value as it gives you OEM foam (and all the other parts too) that you may need to replace.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Sat May 09, 2009 7:00 am
Year and Trim: 2007 Impala SS
1997 LeSabre Limited
I was looking to put leather upholstry in my car. I have the cloth seats. If i understand this correctly, I can just call GM and purchase the leather skins? I might look for a junk yard too. That would be awesome because my seats are just burned from the former owners cigars.
2007 Impala SS - 30k 5.3L V8
1997 LeSabre Limited - 115k
Gone but never forgotten:
2001 Bonneville SE
1992 Bonneville SE
PostPosted: Sat May 09, 2009 8:41 am
The typical price range for a junkyard seat in nice shape is $50 - $100. You should be able to get a better deal by offering to buy all the seats and door panels. Offer $200 for all and work your way up. There is very little market for the back seats. Obviously, the difficult seat to find in good condition is the driver's seat. But in a lot of cases, the skin(s) or covers from a good passenger seat can be interchanged. Typically, the seat back skins are identical but there may be some different cut-outs in the seat skin bottoms from left to right. Depending on the seat, these may be covered by the lower trim pieces on the seat. Seat frames left and right are typically not interchangeable.
Buying new seats from a dealer (if they are available at all) will be breathtakingly expensive.
PostPosted: Sat May 09, 2009 10:32 am
Year and Trim: 2003 SLE || 51k miles
Haro has some charchol colored fronts.
viewtopic.php?f=27&t=8319
-Mike
PostPosted: Sat May 09, 2009 10:45 am
They're 00+. He's referring to his 95.
PostPosted: Sat May 09, 2009 10:47 am
I didnt even notice that. haha
I guess it still applies to ptfair though.
-Mike
PostPosted: Sat May 09, 2009 10:13 pm
ill look into the jy on monday.
and on the side..i totally missed the boat that he's referring to the 95...whoops.
2001 Bonneville SE
1992 Bonneville SE
PostPosted: Sun May 10, 2009 10:11 am
If you're looking for new leather, check out katzkins. They call them seat covers but they're really premade leather skins that you install just like leather from the factory. You can customize them with various options (like different colored/textured inserts, stitching, bunched or flat leather inserts, etc) and it comes with an installation CD.
Reason I recommend them is I'm going this route for my S10. I don't want to buy leather seats from a junkyard because more than likely they will be bucket seats and not bench/bucket like my truck, and will have power crap that my truck does not and that I don't want to hook up.
They aren't cheap (my truck's was $400ish in the quote), but you get brand new custom fit leather in your style of choice.
-Dan
_
_
There are no new unread posts for this topic. Cracked seat leather
kpatteri
Mon Mar 09, 2015 1:14 pm
There are no new unread posts for this topic. leather seat swap
wast3dd3ath
Mon Oct 26, 2015 2:56 pm
wast3dd3ath View the latest post
There are no new unread posts for this topic. My cracked leather seat solutions
red92xblue
23
2810
Thu Jan 22, 2009 11:45 pm
Skippy1827 View the latest post
There are no new unread posts for this topic. Cleaning Suede Leather Seat Inserts
Barry
Wed Jun 10, 2009 11:40 pm
ddalder View the latest post
There are no new unread posts for this topic. Seat covers aftermarket soft leather suede etc.
Inova1joc
15
2864
Fri Feb 17, 2012 7:56 am
deano55 View the latest post
