It is currently Wed Jan 22, 2020 3:24 am
PostPosted: Sun Nov 24, 2019 11:19 pm
Year and Trim: 1965 Bonneville 2 dr hardtop
I have a 65 Bonneville and would like to put a chevy engine in it. Any suggestions for motor mounts or adapters. Would like to talk to someone who has actually made the swap. Any help appreciated.
PostPosted: Wed Nov 27, 2019 10:47 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
In my past builds I've just made my own mounts using square tube and flat bar stock, and use the factory clamshell mounts.
If you have to make the entire thing, including the rubber mount portion, this video has some good ideas as well:
https://youtu.be/6zKmUUM_d4c
If you're looking for a 'bolt on' or kit solution I can't help with that.
If you need a BOP to Chevy bellhousing adapter, they are widely available:
https://www.speedwaymotors.com/Speedway ... PYEALw_wcB
You might also have luck searching under the other B-body cars (impala, Bel Air, Caprice) for stuff that would work, sometimes adapters and brackets are marketed specifically for the popular nameplate but will also work across the platform with little to no modifications.
http://www.brphotrods.com/products/65-7 ... index.html
There are no new unread posts for this topic. 1969 - 1970 Pontiac Full Size Front DISC BRAKE HUB & ROTORS!
mobileparts
Wed Sep 09, 2015 4:56 pm
mobileparts View the latest post
There are no new unread posts for this topic. A Good Source for Parts (and Pictures) 1957 - 1970 Full Size
Ol' Timer
Sun Sep 26, 2010 9:31 am
GsKaWa View the latest post
There are no new unread posts for this topic. classic Pontiac
mike lang
Tue Jan 06, 2009 12:33 pm
mike lang View the latest post
There are no new unread posts for this topic. I NEED A 2 DOOR 1965 PONTIAC BONNEVILLE!!!!
Mr65Bonneville
Sat Dec 27, 2014 4:40 pm
Mr65Bonneville View the latest post
There are no new unread posts for this topic. 1972 Pontiac Bonneville Restoration
amckee
Sun Sep 23, 2012 1:50 am
amckee View the latest post
