It is currently Tue Aug 11, 2020 9:39 pm
PostPosted: Tue Jan 11, 2011 3:10 am
Year and Trim: 1985 LE
My 1985 Bonneville has locking hubcaps. My lock-nuts froze up and are unusable.
Could I use standard hex-nuts on the wheels and be okay?Image
I lost a hubcap too here is a picture of my remaining hubcap: Image
Would you recommend steel snap-on hubcaps, or locking hubcaps?
Thanks for the help!
PostPosted: Tue Jan 11, 2011 3:14 am
er ya go bud images arent working in your original post so i thought id help you out :beerchug:
Wake asked SSEiman01 wrote:
why in the the world do you have or need Vaseline in your trunk??!!..well Leather cleans easy..
PostPosted: Tue Jan 11, 2011 3:37 am
Thanks Wake, how did you do that? :)
PostPosted: Tue Jan 11, 2011 12:50 pm
You should be able to use a standard lug nut. You want to make sure the threads are the same. Hubcaps are just a matter of preference. You might check out the local JY or craigslist and see if you could get a cheap set of rims instead of caps.
Myself, I am not a fan of caps.
PostPosted: Tue Jan 11, 2011 9:52 pm
thanks "myfirstbonnie" -
What's the best way to find hex-nuts with the correct thread for my car? Also, are hex-nuts the same as lug-nuts?
PostPosted: Tue Jan 11, 2011 10:03 pm
Take a lugnut in to your favorite auto parts store and say "I need 20 of these". They will be able to match them up.
Lug nuts are specially designed to hold their wheel in, and have a different seat. I wouldn't just get a set of nuts with the same thread pitch and diameter and throw them on. Get lug nuts.
PostPosted: Tue Jan 11, 2011 10:38 pm
I specified LUG NUTS in my original post in case the OP did not see that.
Autozone has a them with a Dorman part number:http://www.autozone.com/autozone/parts/Dorman-Wheel-Nut/1985-Pontiac-Bonneville/_/N-ijw4yZ6o257?counter=2&filterByKeyWord=lug+nut&fromString=search&itemIdentifier=182541_112574_13244_
PostPosted: Wed Jan 19, 2011 3:04 am
Thanks "myfirstbonnie" and "00Beast", that was helpful.
A secondary question:
If you look up at my pictures, you see a cup-shaped part that fits over the lug nuts and has a long screw at the end.
Would you recommend getting washers to go behind 3 of the lug nuts so that this cup can fit on? I'd like to still use the cups to stabilize the hubcap, which I believe screws onto the cup's long screw.
PostPosted: Wed Jan 19, 2011 9:57 am
Please refran from using PM's for information.
Via PM:
Thanks "myfirstbonnie". I tried to get these lugnuts, but Autozone said they were out of stock online and in store. Could I use the Dorman part number to get them another way? Should Autozone be able to special order them for me, even though they don't currently have them in stock?
PS: I found them on the Dorman site: http://www.dormanproducts.com/p-12277-711-832.aspx
Thanks for your time and help.
You will have to ask them if they can special order them. You can also try other parts stores also. A lot of stores carry the Dorman product line. As for the hubcap mount, ask them if they carry those also.
PostPosted: Wed Jan 19, 2011 1:18 pm
Do not use washers behind the lug nuts. They will not center the wheel or seat correctly.
PostPosted: Tue Apr 26, 2011 3:07 pm
I think in the end I will just buy a new hubcap, and bypass the locks altogether. I've been driving around for 3 mo. with no locks and so far the other three have stayed on fine.
Do you think thats a good idea, or that the locks are necessary?
There are no new unread posts for this topic. Wiper spanner nuts
pstadnyk
Sat Jun 09, 2018 10:05 am
pstadnyk View the latest post
There are no new unread posts for this topic. Spoke Hubcaps
Dons
Sat Dec 18, 2010 12:46 am
human View the latest post
