It is currently Sat Aug 13, 2022 8:33 pm
PostPosted: Wed May 11, 2022 1:00 pm
34k - First and only owner
20024 GXP - i intermittently hear a sort of clicking/grumbling noise coming from the front passenger side. It is there at idle and when driving, but not all the time. I tried adjusting the thermostat thinking that it was the acuatator, but that doesn't seem to be the issue. Any ideas?
PostPosted: Wed May 11, 2022 1:39 pm
Sound is coming from the cabin or suspension?
If in the cabin, did you try adjusting ALL of the actuators? Left temp, right temp, mode and recirc door?
1997 Corvette Coupe | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 75k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 250k | Official Bonneville Hauler
PostPosted: Wed May 11, 2022 6:20 pm
Sound is definitely coming from inside the cab. I already tried all the adjustments to the AC/heater. It only happens intermittently regardless of whether or not the ac is on or off.
PostPosted: Thu May 12, 2022 9:02 am
Remove the 3-7mm screws for the glovebox liner and you'll have full access to the passenger airmix actuator. You'll be able to see visually if its clicking.
PostPosted: Thu May 12, 2022 9:56 am
I will try that. Thank you.
PostPosted: Wed Jun 08, 2022 1:20 pm
Actuator is not the issue. Sound is now happening when I turn the steering wheel to the left. Any ideas?
PostPosted: Wed Jun 08, 2022 10:18 pm
Does it still sound like coming from in the cabin? If so, and you can replicate it by turning the wheel, you should be able to pinpoint it pretty easily. Am I missing something?
PostPosted: Thu Jun 09, 2022 9:43 am
It was the u-joint. Boot was cracked. Replaced and sound is gone. Thanks for the help.
There are no new unread posts for this topic. Attachment(s) Clunk on front Pass side
L82shark
Sat Nov 24, 2012 12:48 pm
L82shark View the latest post
There are no new unread posts for this topic. Driver Side Top Front Pully
Steelworker26
Sun Sep 18, 2016 2:52 pm
Steelworker26 View the latest post
There are no new unread posts for this topic. Clicking noise.
SkiBum1229
Sat Jan 17, 2009 6:37 pm
SkiBum1229 View the latest post
There are no new unread posts for this topic. Circuit breaker clicking on & off
mike5631
Tue Oct 26, 2021 11:09 pm
mike5631 View the latest post
This topic is locked, you cannot edit posts or make further replies. Where to get a Bonneville Passenger Headlight for a GXP?
meen95z
Thu Feb 16, 2012 9:34 pm
