It is currently Fri Jul 23, 2021 3:51 pm
PostPosted: Thu Jun 25, 2020 6:24 pm
Does anyone know an easy way to replace this $20 part? Dealer and other mechanics want $400 in labor. I can see the unit and can get it to turn, but I can't disconnect the plug, so the wire spins with the unit. The engine bracket is right in the way. I guess this is how the service departments stay in business. Any help would be great.
PostPosted: Fri Jul 03, 2020 4:41 pm
Year and Trim: 02 SE and 05 GXP
I just replaced the crank sensors which is about the same thing . take the lower valance plastic down the part under the bumper cover and access the 3 13 mm bolts that way.drop the oil adapter there is no easy way really its not that bad it goes in much easier than it comes out.
PostPosted: Fri Jul 03, 2020 7:51 pm
you need any help pm me
PostPosted: Fri Aug 14, 2020 5:35 pm
I hate to resurrect an old topic, but I don't have enough prestige to send PMs. I have this very same issue with both the oil pressure switch and the crankshaft position sensors on my '05 GXP. I got as far as removing the air dam but I couldn't figure out how to even get a finger up into the space where they are, much less any tools.
From what you posted here, it seemed like you had a different approach vector than the maintenance instructions have detailed. It'd be a great help if you could provide some more detail around how you did this task?
Thanks!
Greg
There are no new unread posts for this topic. Oil Pressure Sending Unit
Loopy
Wed Mar 19, 2014 5:58 pm
rmmartel View the latest post
There are no new unread posts for this topic. Fuel Sending Unit Check
Gagger14
Wed Feb 01, 2012 4:51 pm
Gagger14 View the latest post
There are no new unread posts for this topic. GXP replacement wheels
NashvilleGXP243
11
1713
Tue Dec 22, 2015 12:43 am
jradke61 View the latest post
There are no new unread posts for this topic. Coil replacement
zigger21
Mon Aug 23, 2010 9:19 am
There are no new unread posts for this topic. TIE ROD REPLACEMENT 2004 GXP
mark a. chew
Fri Aug 08, 2014 10:59 pm
Archon View the latest post
