It is currently Mon Feb 24, 2020 1:14 pm
 Post subject: Front End Work.
PostPosted: Sat Sep 07, 2019 12:51 am
Today I replaced the struts on the GXP and I'm having an alignment on Monday. I took it for a test drive after and it seemed to handle well (despite not being aligned yet). There is no pull either direction. Over bumps it is better, but there is still a bit of a clunk in the front end if the bump is big enough and I'm not entirely sure why. Everything has been torqued to service manual specifications, including the WSS and brake cable retainer bolts (because that's just how I am). My last alignment was in 2015 after I replaced both outer tie rod ends. I've only driven 8,667km (5,385 miles) since, and at the time they said everything in the front end was fine. I can't imagine that everything has just fallen apart in such a short distance.
The parts I replaced today include:
Struts.
Strut rod nuts and concave washers.
Upper and lower spring insulators.
Bellows and bumpers.
Strut mounts.
Strut bearings.
Strut to steering knuckle bolts and nuts.
All parts are OEM and the only ones I reused were the springs and body to strut mount bolts.
The car has 128,556km (79,880 miles) so it's not exactly high mileage. In my other recent work I changed the right engine mount. The front mount was done at most about 10,000 miles ago while it was still under extended warranty.
The stabilizer bar bushings, control arms or ball joints have never been replaced. As I recall, several people here have changed the control arms so perhaps there's some movement in the bushings? But, like I say, not a high mileage car. Perhaps the bushings have just deteriorated with age.
Any thoughts?
 Post subject: Re: Front End Work.
PostPosted: Tue Sep 10, 2019 2:40 am
I had my GXP into the shop Monday and the report shows pre-alignment LF toe and front total toe were barely out of spec. These were both corrected. The only other abnormal value is the RR camber (-0.9 degrees) which is 0.1 degrees out of range (-0.8 through +0.2) and has not been corrected. This finding has been reported at every alignment I've had done. The rest of the suspension components were fine. I'm not sure that they thoroughly assessed the control arm bushings, so I'm still looking for possible solutions to the slight clunk.
PostPosted: Thu Sep 12, 2019 2:34 pm
I was gonna throw out control arm bushings if you're still hearing a clunking.
PostPosted: Thu Sep 12, 2019 3:22 pm
Thanks, Lane. I'd have to say that everything is 90% better than before the struts. I was kind of leaning toward control arm bushings as well, but I don't have a huge amount of experience with front end work so thank you for chiming in. I will definitely have a closer look at them.
PostPosted: Thu Sep 12, 2019 5:53 pm
Make sure to check the ball joint on the LCA in addition. The ball joints can be a heavy wear part and that could be where it's coming from. IIRC on this chassis, you can replace the ball joint on it's own and wouldn't need a whole new control arm like some.
PostPosted: Thu Sep 12, 2019 8:34 pm
Thanks. I will check those as well. I was hoping if the alignment tech found any extent of wear that they would have told me. Having said this, I admittedly didn't say there was still a slight noise when I dropped it off. ACDelco lists them in their parts catalog so that confirms your suspicion that they are replaceable. It doesn't look overly hard to do.
There are no new unread posts for this topic. radio display doesnt work
wilsonracing
Fri Dec 29, 2017 3:08 pm
There are no new unread posts for this topic. HVAC does not work in drive .Ok in park or rev.
brettb
29
2847
Thu May 22, 2014 11:01 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Front End Chirp
jml2884
16
2281
Tue Jun 18, 2013 12:12 am
There are no new unread posts for this topic. Front Suspension
PaulyGXP
14
2172
Tue Nov 27, 2012 12:06 pm
There are no new unread posts for this topic. Front End Parts
GXPete
19
4598
Mon May 03, 2010 2:33 pm
