It is currently Mon Jul 13, 2020 11:36 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Aug 02, 2019 1:24 pm
I did the injector test - all injectors were dry when the key turned on - no apparent leakage.
- Rich
PostPosted: Fri Aug 02, 2019 4:16 pm
Year and Trim: 2004 Pontiac Bonneville GXP
Still does not confirm the injector is operating the way it should, but good that it's not leaking. Key off, jump the relay terminals. Pull the starting relay and touch a jumper wire across the two terminals (diagram on relay itself). It will only crank as long as you jump it with that wire and with the key off it will not start.
PostPosted: Mon Aug 05, 2019 11:51 am
Since this thread is public, I might as well say it. The OP did a compression test and found 0 PSI on cylinder #6. 11 years in the business and this has never happened to one of my builds.
Since no "clang-bang" noises were heard, I assume the only way this is possible is if two roller finger followers fell out of position. Either a bad bearing inside the RFF or hydraulic lash adjuster failed to pump up and take up slack. I have seen RFF's dislocated twice on a Northstar. This is the first time on one of my builds, if I am right about the cause.
Due to a foot injury I can't take care of this immediately but I will ASAP so that Rich can enjoy his car again.
PostPosted: Mon Aug 05, 2019 12:21 pm
All I can say is stuff happens... It's mechanical - anything can happen and can go wrong. I am an IT consultant - believe me I have seen it all with computers. Jake, if there is anything I can do ahead of time to prepare let me know. Or if there is anything I can do to somehow confirm your suspicions. Either way, yes looking forward to getting it running again.
Rich
PostPosted: Mon Aug 05, 2019 2:16 pm
Online
I'm glad it was found and hopefully no further damage is a result. No one here is going to hold it against you Jake. For what you have done for N*'s, stuff happens that is out of your control.
PostPosted: Sat Aug 24, 2019 4:04 pm
Thanks CMNTMXR57. I appreciate the kind words. I took the front cam cover off to find a couple of roller finger followers out of position, just as I had figured. Almost anything else that would cause compression loss to 0 PSI, would have most certainly made some serious noise. These were brand new GM heads with all new valvetrain parts as from the GM plant. This is the third time I've seen this in my history of repairing these, but first time on one of my builds. It's repaired again and ready for Rich to enjoy and hopefully for many, many, many miles to come.
I sincerely apologize to the OP. The only way I can explain this is as Rich had said, with mechanical stuff things will happen. I don't want it to happen to my customers, for sure. I verified compression was restored before reassembly. I'll take it for a test drive yet since Rich gave me permission to do so. I don't want him having any further issue with the car.
PostPosted: Wed Oct 30, 2019 10:50 am
OK.. finally got the car back on the road and it's running awesome! Hopefully no more issues. I am fighting with an electrical drain issue (posted in another thread) but that one is somewhat minor although it killed my brand new battery. Thankfully it's under warranty so they replaced it no questions asked. Car just needs to be driven - I guess that's the solution for the drain - don't let it sit. It's fun to drive anyway!
Thanks Jake for your hard work - took a while but in the end I think I'm money ahead doing this rather than putting the same dollars into a different vehicle.
Rich
There are no new unread posts for this topic. 2005 GXP troubleshoot P0420
rwebb616
Wed Dec 04, 2019 2:58 pm
rwebb616 View the latest post
There are no new unread posts for this topic. Project 2005 GXP: HOW-TO: Northstar Engine Swap
94SilverSSEi
Fri Jul 28, 2017 11:06 pm
There are no new unread posts for this topic. P0300 DTC
sethjamesrimrodt
Tue Nov 06, 2012 10:58 pm
dpnewfie View the latest post
There are no new unread posts for this topic. P0300 code
bobgto65
Tue Aug 09, 2016 12:01 pm
There are no new unread posts for this topic. Water in spark plug well P0300 code
Steelworker26
Tue Dec 11, 2018 1:45 pm
Steelworker26 View the latest post
