It is currently Thu Aug 06, 2020 8:31 pm
PostPosted: Wed Jul 10, 2019 11:05 pm
Just wondering if there is a preferred lubricant to apply to the harmonic balancer when reinstalling it onto the crank so the front cover seal isn't damaged, or if clean motor oil is sufficient?
PostPosted: Thu Jul 11, 2019 6:31 pm
I ended up using a synthetic, general purpose grease (Super Lube, which happens to also be food grade in case I want to dine on used motor oil later). I was pretty surprised because I dropped by a well known and established store that sells parts and supplies for modding and building high performance engines. I asked if there is a "preferred" product (understanding that likely a bunch of general purpose products will be fine). The guy at the counter had no idea. He said they don't build engines so I should call a machine shop.... :banghead:
There are no new unread posts for this topic. Plastic cover under front end.
mblaze
Thu Apr 12, 2012 11:30 am
yonkerse View the latest post
There are no new unread posts for this topic. Aftermarket Radio Installation
JDArbital
Thu May 14, 2015 10:46 am
There are no new unread posts for this topic. Cowl cover on GXP
sextrosgxp
22
4743
Tue Jul 03, 2012 3:02 pm
There are no new unread posts for this topic. GXP License Plate Cover
Loopy
Fri Nov 04, 2011 9:08 pm
Loopy View the latest post
There are no new unread posts for this topic. Oil Pan and Timing Cover Gaskets
obis88
Wed Mar 09, 2011 3:51 pm
