It is currently Tue Jul 14, 2020 12:43 am
PostPosted: Mon Jun 10, 2019 6:49 pm
Year and Trim: 2004 GXP
Like the subject says. The left side is blowing hot on defrost, the floor and vents while the right side works with the temp dial normally. It does the same while the AC is on as well.
PostPosted: Tue Jun 11, 2019 6:43 pm
2005 GXP
Drivers side blend door actuator has failed.
PostPosted: Thu Jun 13, 2019 10:13 am
you can try to reset the door by removing(( -) cable from battery for 30 sec. if that doesnt work, you can move the door to hot position in winter and cold position for the a/c.
PostPosted: Thu Jun 13, 2019 1:00 pm
This is one of the things listed in the common problems post at the top of the 2000-2005 section.
There are no new unread posts for this topic. No air out of dash vents
05joenov
Fri Dec 09, 2016 9:52 am
This topic is locked, you cannot edit posts or make further replies. Where to get a Bonneville Passenger Headlight for a GXP?
meen95z
Thu Feb 16, 2012 9:34 pm
There are no new unread posts for this topic. Loss of all electricals for passenger doors.
jonathan0694
Wed Apr 01, 2015 1:12 am
mikeluscher159 View the latest post
There are no new unread posts for this topic. driver door issue...
gxp937
Thu Jan 08, 2009 1:30 am
GXP Venom View the latest post
There are no new unread posts for this topic. Leaky driver door window
inovermyhead
Tue Oct 14, 2014 5:29 pm
