It is currently Tue Jul 14, 2020 1:06 am
 Post subject: Cabin Fan Issues
PostPosted: Sat Mar 02, 2019 9:33 am
Year and Trim: 2004 GXP
Seems like 25 percent of the time I start the car the interior fan will not run. Then as I'm driving it will randomly turn on. Once the fan is running it will stay on and work fine. It only does this when the car is started. It never shuts off when running unless you turn it off manually. It will turn back on if turned on. Has anyone experienced this issue?
 Post subject: Re: Cabin Fan Issues
PostPosted: Sat Mar 02, 2019 11:27 am
2008 Grand Prix GXP
I think that is normal, because the fan will run when only the temperature of the engine is warming. So it doesn't blow cold air into the passenger compartment. Do you have automatic climate control?? I do on mine. And that's how it operates. Hope this helps.
PostPosted: Sat Mar 02, 2019 1:51 pm
I do have the auto climate control. It doesn't seem normal when it's 20 degrees out and the fan doesn't come on during a 30 minute drive.
PostPosted: Sun Mar 03, 2019 1:03 am
I don't ever recall my fan not running at all in cold weather. I know with the automatic climate control the fan will increase in speed as the coolant warms up. It seems like you may have a bad motor. You should also check the wiring and connector between the fan and control module to make sure there is no corrosion or signs that it got hot and melted. There are some other possibilities as well but this is where I'd start. I had a lot of motors in various cars over the years that needed to be bumped to start spinning but once they were running, kept going until they were shut off again.
PostPosted: Sun Mar 03, 2019 12:11 pm
2005SLE WHITE
1975 MONTE CARLO
I was having the same problem with my 2005SLE.
Sometimes it would run and if you hit a bump it would stop.
It turned out it was a bad motor.
Replaced with a new one and the problem went away.
The fan should run no matter what the temperature is.
There are no new unread posts for this topic. Cabin Air Filter
Napenthe
Fri Jul 17, 2009 11:02 am
There are no new unread posts for this topic. Cabin air filter deal
shoto
Sun Mar 14, 2010 9:31 am
There are no new unread posts for this topic. Overheating and No Cabin Heat
04BlackGXP
22
3683
Tue Nov 27, 2012 10:47 pm
L82shark View the latest post
There are no new unread posts for this topic. Wind noise in cabin from windshield ?
05Bonnie&Clyde
Thu Jan 26, 2012 10:12 am
05Bonnie&Clyde View the latest post
There are no new unread posts for this topic. DIC issues
VAbonnyGXP
Wed Jun 15, 2011 10:06 pm
Bvill_GXP View the latest post
