It is currently Sat Jun 06, 2020 12:26 pm
PostPosted: Tue Oct 02, 2018 8:41 pm
Does anyone know the readings you should get from the Front impact sensor? I'm guessing it's the same sensor for either the regular Bonne or the GXP. Mine has a number on it 25764117.
I'm reading 11.63 Meg Ohms one way and open the other... I think it's correct to have open one way and resistance the other but I don't know what the measurement should be. I'm trying to figure out why my airbag light is on. I have no codes showing currently with the scan tool but I seem to recall getting a code when it first happened long long ago (maybe 2 or more years ago now) with something about the front sensor. I never bothered to try to get to the bottom of it yet but I'm finally getting around to fixing all the little annoyances.
I checked the 15A fuse and that is good. I reseated the connector and put the fuse back in and started the car and the light flashed and went out and I thought yay I fixed it then it came back on about a second later.
I just don't want to part with upwards of $120 to replace a part that may not be bad.
Any suggestions?
Rich
PostPosted: Wed Oct 03, 2018 9:26 am
Get a scantool that can properly read the body codes. A regular code reader will not do it. You're only throwing the parts cannon until you get the code.
-Andrew-
PostPosted: Tue Oct 09, 2018 10:52 pm
Well I found a sensor on ebay for $79 matching my part number with a return policy. I took a chance and ordered it. I forgot to test what the measurement should be but I replaced the sensor and no more air bag light. Problem solved!
-Rich
There are no new unread posts for this topic. Testing
Pontiac Bonneville Club
Sat Dec 20, 2008 1:04 pm
Gumball View the latest post
There are no new unread posts for this topic. 02 sensor help
J.R.
11
1505
Mon Sep 15, 2014 12:42 pm
Archon View the latest post
There are no new unread posts for this topic. O2 sensor locations
jimbo
Mon Jul 16, 2018 5:25 am
jimbo View the latest post
There are no new unread posts for this topic. Bad Sensor or Relay??
White64Goat
Sun Dec 25, 2016 7:11 pm
White64Goat View the latest post
There are no new unread posts for this topic. O2 sensor code P0136
rmmartel
17
2983
Wed Jul 08, 2015 10:27 am
