It is currently Wed Jan 23, 2019 8:45 pm
 Post subject: Speedo problems
PostPosted: Sat May 12, 2018 12:49 pm
So I have a 2004 GXP. Only had it for about a year. Had the bouncy Speedo when I got it. Replaced the output speed sensor and it fixed it for a while. I have since replace all the stepper motors as well. The other day the Speedo started the same weird behaviour as before. So I figured since the speed sensor was a cheap one I got a better quality one and changed it again. I also changed the connector. First I put the connector on with crimp connectors but when I drove the car the speedometer didn't even register. So I redid that by soldering and heatshrinking the electrical connection. Immediately took the car on an hour and a half drive and it was perfect for an hour and 15 minutes then the Speedo started bouncing around again. Then the next time I started it, the Speedo needle didn't move at ball again. Registers 0.
Could it be the input speed sensor? Or something in the transmission? The transmission shifts hard when the speedometer is not registering speed. I'm at a loss...
 Post subject: Re: Speedo problems
PostPosted: Mon May 14, 2018 8:21 am
I would first check wiring from the servo to where it terminates. - continuity test -
PostPosted: Sat May 19, 2018 11:24 pm
Also, look at the speed sensor end...is it getting full of metal shavings on the magnet?
There are no new unread posts for this topic. AC Problems
mblaze
Sun Apr 10, 2011 11:47 pm
mblaze View the latest post
There are no new unread posts for this topic. Turn signal problems
sextrosgxp
Sat Jul 21, 2012 1:13 pm
sextrosgxp View the latest post
There are no new unread posts for this topic. Yet more problems with my GXP. MAP sensor location
NashvilleGXP243
Sat Mar 12, 2016 2:08 pm
NashvilleGXP243 View the latest post
There are no new unread posts for this topic. More Problems, high idle.
havoc1482
Wed Aug 24, 2016 3:53 am
bobc997615 View the latest post
There are no new unread posts for this topic. 04 GXP check engine codes and other problems
clokworkpenguin
Tue Jul 25, 2017 12:50 pm
cron
