It is currently Fri Mar 22, 2019 5:56 am
 Post subject: Battery Question
PostPosted: Fri May 04, 2018 10:55 am
Year and Trim: 05 bonneville GXP
I'm looking for a Battery for my 05. There are two, one the exact fit. The other one does fit. They look to be the same specs. The exact fit is $60 more. Anyone have some input on either.
 Post subject: Re: Battery Question
PostPosted: Fri May 04, 2018 12:09 pm
Online
2008 Grand Prix GXP
What Brand are they?? My own opinion... I would purchase the exact fit, since your battery is under the rear seat. You need to be sure it is vented properly. And secured well. Also. I know. $ 60 more could strap your budget, but for me piece of mind is priceless.
PostPosted: Fri May 04, 2018 12:50 pm
YES, the 60+ is prob vented and the cheaper is not - I use a non - vented one in my 2000 and there are no issues. as long as the cranking amps meet specs, you should be good with either
PostPosted: Fri May 04, 2018 12:56 pm
I would get the proper vented one, you just never know when someone inside might get sick over something and it be tracked back to that. But I get that $60 speaks a lot more than venting.
Anyway, Batteries are made by two or three main companies and all these sellers do is put their case and/or labels on it. Meaning most are pretty much the same internally for the class of battery you're takling about. What you're paying for is the warranty on any battery to be quite honest.
PostPosted: Fri May 04, 2018 7:12 pm
That's what I was thinking. You Guys are always a wealth of information, thanks
PostPosted: Fri May 04, 2018 9:23 pm
After a little research, both Batteries are externally vented.. They're a 100 and 78 Group Battery.
PostPosted: Fri May 04, 2018 10:21 pm
One thing to be mindful of, if you're on the original battery, the OEM AC Delco battery is longer than any replacement IIRC.
PostPosted: Sat May 05, 2018 12:21 am
Oh, ok thanks.
PostPosted: Sun May 06, 2018 2:16 am
As mentioned, the GXP uses a battery of a different physical size (longer) than the SE/SLE. The vent tube assemblies are also a different. If battery listings are anything like lights, they frequently don't differentiate GXP parts properly. All 2000+ Bonneville batteries are externally vented, so this really isn't a criteria (unless the listing is way off base).
Hydrogen gas is explosive in certain concentrations. This can collect under the rear seat in the same space as the fuse block which, does not use intrinsically safe relays. I can't say whether the gas would ever reach explosive levels, but this is also the reason that your last connection when boosting a vehicle should not be made at the battery. If I'm not mistaken, hydrogen gas (over time) may also affect the integrity of the seatbelt webbing and seat foam.
Personally, I think it's just a poor choice to use the wrong battery here.
There are no new unread posts for this topic. Age of battery
fiveandcounting
15
3037
Mon Jul 02, 2012 5:02 pm
There are no new unread posts for this topic. Battery Help
Gagger14
Sat Jan 07, 2012 11:22 am
Gagger14 View the latest post
There are no new unread posts for this topic. New Battery Time!!!
Bvill_GXP
21
5408
Thu Jan 19, 2012 9:12 pm
jedwards83 View the latest post
There are no new unread posts for this topic. Parasitic Battery Drain?
White64Goat
Thu Aug 10, 2017 2:21 pm
96 SSEi View the latest post
There are no new unread posts for this topic. ELECTRICAL OR BATTERY LIGHTS BLINKING ON AND OFF IN 05 BONNE
bigrod64
Sat Mar 31, 2012 9:36 pm
bigrod64 View the latest post
Users browsing this forum: mark a. chew and 3 guests
