It is currently Mon Apr 12, 2021 2:58 am
 Post subject: Rust on rotors
PostPosted: Sat Sep 06, 2008 6:02 am
98 SE
Olds Aurora Final 500
With the wide open rims on the GXP's, the rust on the rotors really shows through, especially the rears. Is there anything I can do to make this look better?
Thanks
 Post subject: Re: Rust on rotors
PostPosted: Sat Sep 06, 2008 7:48 am
You can replace the rotors......
or you can paint them with some light coats of high heat VHT high temp rust spray paint.
:bsnicker: Don't drive in the rain.
PostPosted: Sat Sep 06, 2008 7:52 am
If you are talking about the shiny part that the pads rub on.....there's nothing you can do. Mine show a little rust every now and then. The cure is:
Keep driving it, it rubs off the first time you apply the brakes.
But other than that the only way to keep the rust off the hub area is to paint them as mentioned above.
PostPosted: Sat Sep 06, 2008 8:09 am
Oxysolve rust cleaner from Eastwood.com
Leaves them with a zinc coating after a 15 minute soaking to prevent rust.
I've never tried the stuff but seen it used on a classic car show once.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:
Every time you pat my head, you pat a piece of my valve retainers.
PostPosted: Sat Sep 06, 2008 1:14 pm
98 SE
Yes, I'm talking about the rust on the hub part. Sorry. Thanks for the info.
PostPosted: Wed Sep 10, 2008 10:12 pm
Banned
Year and Trim: 05
Psssssst.........BBQ Paint.Takes high heat, dull black, kinda stealth, cheap,......one can lasts a long time.
PostPosted: Wed Sep 10, 2008 11:13 pm
Duplicolor spary can Hi Heat 1500 F comes in many different colors. I like Silver. :wink:
PostPosted: Sun Sep 14, 2008 11:46 pm
Just use the Dupli Color Brake Coating, or if you're worried about heat, then the Hi Heat in black, so it disappears, and matches your black car. Just my $.02
This topic is locked, you cannot edit posts or make further replies. Rust on rotors
CincyGXP
Sat Sep 06, 2008 6:03 am
CincyGXP View the latest post
There are no new unread posts for this topic. Rotors?
Bvill_GXP
Mon Feb 01, 2010 12:34 am
There are no new unread posts for this topic. GXP rotors
pontiacfanatic
Sun May 27, 2012 2:53 pm
repinS View the latest post
There are no new unread posts for this topic. Turnable Rotors?
5448
Fri Jan 01, 2010 6:30 pm
There are no new unread posts for this topic. Brake Rotors
Gagger14
15
3209
Tue Jan 03, 2012 12:22 pm
dpnewfie View the latest post
cron
