It is currently Sat May 25, 2019 4:52 am
 Post subject: Coil Packs
PostPosted: Tue Jan 23, 2018 12:45 pm
Year and Trim: pearl white 2005 GXP
I am receiving an error code indicating that cylinder 8 is misfiring. I have replaced the spark plugs but am still missing. The next step is the coil pack. I have the early version pack with the white epoxy. Since they are out of production the only way I can buy them is if I get the whole rail of four packs. It is cheaper to get the newer packs with the black epoxy. My question is can I change to the new design without issue? And if I only change the one bank will that cause issues with the other side of the engine still running the old design coils?
 Post subject: Re: Coil Packs
PostPosted: Tue Jan 23, 2018 5:24 pm
hi, you can check the wire also - seats properly and no fraying. swap it with a good one to test.
PLUG,WIRE,COIL,ICM,CPS,PCM is the backward order of ignition.
PostPosted: Tue Jan 23, 2018 5:25 pm
Have you contacted Andrew (Harofreak) on this board. He may have an individual coil.
As far as mixing and matching, you should be fine. There may be numerous updates with the newer ones, but I think the main one is the spring adjuster where they make contact with the plug that had a revision for better contact.
PostPosted: Tue Jan 23, 2018 5:26 pm
The newer LD8 N*'s don't have wires. It is a CNP setup with a direct coil over plug.
Another suggestion, swap coils with a working cylinder and see if the misfire transfers with it. That'll tell you whether or not it's the coil.
PostPosted: Tue Jan 23, 2018 5:28 pm
LD8
PostPosted: Tue Jan 23, 2018 5:48 pm
ooooh...lol
PostPosted: Tue Jan 23, 2018 6:51 pm
I have what you need, PM me.
-Andrew-
PostPosted: Sun Mar 11, 2018 12:38 pm
What car is the above LD8 out of?
Drew
Pontiac stable:
2005 Bonneville GXP - Black -daily driver
2004 Sunfire - Arrival Blue Metallic -Wife's
1998 Grand Prix GT - Black -seen better days, awaiting fate
1985 Fiero Sport Coupe - Black (mostly) - long term rebuild
PostPosted: Mon Mar 12, 2018 12:13 pm
Are you referring to the pic above that I posted?
If so, that is out of a 2005+ LD8 in a RWD STS. The give away is the TB and the VVT actuators ("cam phasers" in GM speak). :)
I just picked a picture of a newer N* that had the modular coils we reference.
There are no new unread posts for this topic. Coil Packs
mblaze
11
3873
Tue Oct 09, 2012 12:09 pm
cjbennett01 View the latest post
There are no new unread posts for this topic. coil pack
drskunk
12
1282
Thu Jul 10, 2014 10:48 am
There are no new unread posts for this topic. Coil replacement
zigger21
Mon Aug 23, 2010 9:19 am
There are no new unread posts for this topic. where can I buy a single coil for a 2004 GXP northstar?
naasz
Sun Mar 22, 2015 11:15 pm
