It is currently Sat Feb 16, 2019 4:54 am
Post new topic Reply to topic  [ 17 posts ]
 Post subject: Not Enough Heat!
PostPosted: Thu Dec 28, 2017 11:44 am
Year and Trim: 2004 GXP
2003 SLE [SOLD]
Very COLD up here in the great white north this week! -33C here early this morning! :canada:
Despite having the heat cranked up as high as it will go, its still not that warm inside the car... While the air is warm coming out the vents, its not as warm as it should be. The engine itself is heating up to normal operating temperature. Not sure where to look first...
Thanks for your help!
 Post subject: Re: Not Enough Heat!
PostPosted: Thu Dec 28, 2017 2:29 pm
2003 SLE [SOLD]
I should add that the coolant level is normal, and the thermostat has been changed. Head gaskets and studs were done too, so I'm pretty confident there are no issues with the engine itself.
PostPosted: Fri Dec 29, 2017 1:13 pm
Start by checking the hoses to the heater core. Are they both the same really warm temperature? If not, the heater core is likely partially plugged. A back flush may help, or it will have to be replaced.
Check the coolant mixture to be sure that it is the proper mix. Too much coolant vs water can lower its ability to absorb heat.
Does the temperature change when you adjust the temperature? If not, it likely a bad actuator.
PostPosted: Fri Dec 29, 2017 3:09 pm
Blend door actuator(s).
It is a problem with this generation car (not just a GXP issue), as well as other GM FWD vehicles.
PostPosted: Fri Dec 29, 2017 5:24 pm
2003 SLE [SOLD]
Thanks guys. I will have a good look at it once temps warm up a bit and I thaw out... LOL!
PostPosted: Fri Dec 29, 2017 6:03 pm
nothing like heat problems when it's too cold out to want to fix them...
PostPosted: Fri Dec 29, 2017 9:32 pm
2003 SLE [SOLD]
A bit of research tells me there are 3 actuators? Left, right, and main? Since both sides heat equally, I'm guessing the main one is suspect?
Thanks.
PostPosted: Sat Dec 30, 2017 11:43 am
2003 SLE [SOLD]
Something else I should mention too... Not sure if it's related to the heat issue.
Sometimes, there is a noise in the dash. It seems to be coming from behind the glove box. It's kind of a faint rhythmic type noise, like something is cycling on and off repeatedly. No idea what it is....
Thanks again for your help guys!
PostPosted: Sat Dec 30, 2017 12:46 pm
That does sound as if one of the actuators is not working properly. The gear inside can crack, causing a clicking type noise. You'll have to remove the knee bolsters on each side. Then look in the center part of the dash for the actuators.\
Observe those actuators as you adjust the controls. You should be able to see if they are moving properly. In the second picture, actuator #3 is tucked well back toward the firewall, so it will be hard to see.
PostPosted: Sun Dec 31, 2017 7:57 pm
2003 SLE [SOLD]
Pulled things apart today, and all 3 actuators seem to be functioning ok.... And of course it wouldn't make any strange noises the entire time I was testing it... :roll: :dontknow:
PostPosted: Mon Jan 01, 2018 12:45 pm
There should be 4 actuators. Two on the driver's side, and two on the passenger side. Only one on the passenger side is easily visible. The inlet actuator is hard to see, as mentioned previously. This gives a better view of it.
PostPosted: Mon Jan 01, 2018 12:56 pm
2003 SLE [SOLD]
Found both on the passenger side, but only one on the drivers side. I will take a second look. Is any one of them more prone to giving out than the others?
Thanks.
PostPosted: Mon Jan 01, 2018 8:27 pm
2003 SLE [SOLD]
So there are 4 actuators, two are for the temp control, [one on each side] and a third for the air inlet, and what does the fourth one do?
PostPosted: Mon Jan 01, 2018 9:24 pm
Mode actuator, which directs which vent the air blows from.
PostPosted: Tue Jan 02, 2018 8:56 pm
2003 SLE [SOLD]
I am really starting to HATE this car....
Took it to my local garage today, and they did a scan for me. I'm told all the actuators are working as they should. They seemed to feel that the fan is not blowing as much air as it should, and that the heater core is likely clogged with dust and dirt. I guess the previous owner removed the cabin filter, and never replaced it... :roll:
So.... I decided to try and clean it out. I removed the console, the duct work needed to get at it, [a real pain in the A$$] and I come to discover the heater core is not dirty at all... :banghead:
Now I'm trying to reassemble it, and I can't get the plastic heater cover to go back on properly... Things just don't want to line up...
Like I said, I'm really starting to hate this car... :cussing:
PostPosted: Wed Jan 03, 2018 12:19 am
You're chasing an erratic problem is the issue...
In this post you noted that it makes a noise. My guess is something like a constant "click, click, click" or a "grinding". This is a tell-tale sign of the actuators being the problem. If it's not making noise, it IS in fact working and won't trigger any issues. It just may be in the wrong position hence why you're not getting the heat. But that's why they're walking past it because it isn't acting up when you need it to.
Case in point, in summer, Our Impala did this when you try to go from open air to recirculate and will do it even after shutting the car off for a few minutes. So I replaced it then and just this past summer it'd do it sporadically. SO when it's not making noise, it's functioning properly and won't flag any issue.
PostPosted: Thu Jan 04, 2018 1:49 pm
2003 SLE [SOLD]
I managed to get it all back together, and it seems to be making decent heat... at least for now. Hasn't made any more noise either... Intermittent problems can be a real pain in the A$$ to find! I do know one thing for sure though... I do not want to be taking it apart again!
There are no new unread posts for this topic. Erratic Heat
Loopy
Mon Feb 27, 2012 11:34 am
There are no new unread posts for this topic. Overheating and No Cabin Heat
04BlackGXP
22
3035
Tue Nov 27, 2012 10:47 pm
L82shark View the latest post
There are no new unread posts for this topic. 05 GXP - No heat at idle - car heats up
cougarcat454
12
700
Thu Jan 25, 2018 11:44 am
cougarcat454 View the latest post
