It is currently Wed Feb 21, 2018 10:40 am
PostPosted: Tue Aug 15, 2017 10:14 am
Year and Trim: 95 SSEi
05 GXP
Is it the ACDelco 503-589? only $62 on Rock Auto.
or the ACdelco 506-254 (which is soft ride FE1 and FE2)
Any other options which are close to original?
I'll swap my springs, hopefully they aren't toast.
Black 95 SSEi (original owner) 236K miles
Black 05 GXP (some idiot put the first 12K on it)160K miles
Black 04 Tahoe (original owner)264K miles
Black 16 Traverse (original owner)30K miles
PostPosted: Tue Aug 15, 2017 10:34 am
you can check the springs by measuring trim height - One of the ex gm guys may have the specs and where they are measured.
I put monroe air max on my 2000 SSEi and they handle slightly better than stock and provide a smooth ride. - they are direct fit, which is nice and fast.
PostPosted: Fri Aug 18, 2017 9:59 am
05 GXP
I just need a couple options that fit height wise and handling feels somewhat normal.
If no one has good results to recommend then I will leave the old ones and
just change the failing mounts.
These Monroe air max, do they fit the GXP?
PostPosted: Fri Aug 18, 2017 10:12 am
The 589s are the stiffer ones, that's what I would do personally. Swap your springs over, they should be fine. Grab some ACDelco strut mounts as well. I used Moogs and not the happiest outcome. A little noisy 30k down the line. Definitely not bad or broken by any means, but a little bit annoying.
"Penelope" - 169k Miles
PostPosted: Fri Aug 18, 2017 5:56 pm
Max-Airs are the rear shocks. Not applicable to this thread.
PostPosted: Sat Aug 19, 2017 5:05 pm
05 GXP
Thanks guys, I'll report back the outcome.
The mounts are toast and growling badly, struts have 160K on them
so might as well do it all at the same time.
There are no new unread posts for this topic. GXP struts
Royal Termite
Tue Feb 23, 2016 11:51 pm
skregal View the latest post
There are no new unread posts for this topic. GXP shocks and struts
Bigerik
Sat Jun 05, 2010 12:25 pm
Bigerik View the latest post
There are no new unread posts for this topic. Front struts on a 2005 GXP
DCMain
Thu Dec 25, 2014 11:37 am
idensm View the latest post
There are no new unread posts for this topic. What are some good brake pads for a 2005 Bonn. GXP ?
Arrowhead
24
2062
Fri Aug 16, 2013 11:51 am
