It is currently Wed Sep 26, 2018 1:23 am
 Post subject: Sunroof Drain Hoses
PostPosted: Sun Jun 11, 2017 11:58 am
Year and Trim: 2005 White Gold GXP
I have read most of, if not all the sunroof posts but have a few year specific questions that other posts didn't seem to answer.
I assume most of the leaks are caused by the plastic drain tubes coming disconnected from the rubber drain lines, that being said, on the 2005, where are the drain lines for the rear drains routed? Do they exit down through the rear seat side trim panel area or do they run through the trunk and exit behind the rear wheel? I've seen pictures for 2000 and 2004, but not the 2005. If they exit through the trunk area, where is the connection from the tube to the rubber hose located? Thanks.
 Post subject: Re: Sunroof Drain Hoses
PostPosted: Sun Jun 11, 2017 2:23 pm
2008 Grand Prix GXP
The tubes for the rear on my 04 GXP drains are in the trunk... pull back carpet from the side of
the trunk, back part of the wheel well (in trunk) the tubes connect to a grommet that will exit out the rear fenders.
mine were lose and not angled properly, I used zip ties as hose clamps. hope this helps
the connections are in the shape of an "L" just so you know.
PostPosted: Sun Jun 11, 2017 5:53 pm
2000-05 are all the same. There is no difference in this body style design. As mentioned, the rear don't connect to a rubber hose, only to a body grommet that the body wiring also passes through. There's a duck bill type valve on the exterior side of the grommet to prevent water from entering the trunk from the outside.
There are no new unread posts for this topic. Parasitic Battery Drain?
White64Goat
Thu Aug 10, 2017 2:21 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Sunroof Questions
Gagger14
Fri Sep 23, 2011 10:46 am
There are no new unread posts for this topic. Sunroof Leaks
300sflyer
25
2465
Sun Jan 31, 2016 9:51 pm
MKMike View the latest post
