It is currently Fri Jul 10, 2020 8:24 am
 Post subject: temp gauge
PostPosted: Tue Jun 23, 2015 5:59 pm
So any issue i have with my car i google and the first results (and most helpful) are from here. But my latest issue wasnt exactly on here so im asking my first question to see if anyone has any idea and/or a solution.
My temp gauge seems to get stuck anywhere from 1/4 to half when off. The first i noticed i just drove from one part of my college to another, about 5 minutes, and saw that my temp was in the red. This was after i drove to my first class, so as soon as i got to the parking lot i turned off the car and noticed temp needle didnt go back to the off position it stayed at little below the middle. So i turned it back on and it went right to the red again its like if it were offset. I thought it was because of the freezing temperatures. The car hasnt ever overheated it just appears that the needle doesnt reset and starts from were it freezes. The only thing that is cosistant with the issue is that its after a long drive (45+ minutes) and after i shut it off from the long ride.
Has this happened to anyone or anyone know whats the issue?
thank you
Parker
 Post subject: Re: temp gauge
PostPosted: Tue Jun 23, 2015 6:40 pm
Year and Trim: 2004 GXP
Bad stepper motor. I had mine replaced on all gauges for $100. If you have a soldering gun you can by the motors on Amazon or Ebay for like 10 bucks and take it apart yourself.
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
There are no new unread posts for this topic. Temp Gauge Hot then Normal
Loopy
Thu Mar 14, 2019 10:55 pm
RJolly87 View the latest post
There are no new unread posts for this topic. Crazy Temp Gauge
Loopy
Tue Apr 19, 2016 11:05 am
There are no new unread posts for this topic. Outside temp
donky4444
Sat Jun 14, 2008 11:08 am
donky4444 View the latest post
There are no new unread posts for this topic. coolant temp. switch
mark a. chew
Fri Nov 23, 2012 3:52 pm
mark a. chew View the latest post
There are no new unread posts for this topic. Fuel Gauge
dpnewfie
20
6019
Thu Dec 02, 2010 11:58 am
