It is currently Sun Dec 15, 2019 8:19 pm
PostPosted: Tue Feb 25, 2014 1:34 pm
Hey everyone,
I am new to this site and a new, but proud, owner of a 2005 Bonneville GXP. I received this car as a graduation gift and it only has 35k miles on it. I recently took it in to get two new tires and during the installation and the alignment process, the mechanic pointed out that the wheel bearing on the front, right wheel was loose. He said this could alter the alignment and throw that particular wheel out of alignment. He quoted me at $250 to replace the bearing. I then went to another shop for a different quote and he quoted me at about $300 to install the new bearing. When I asked him about the urgency of replacement, he told me I should do it within the next couple weeks. He told me that if the loose bearing breaks, the entire wheel could fall off.
I was not born yesterday and I know that many mechanics will often times dramatize the situation in order to get the business, so I am inclined to believe that both shops were pulling my leg. However, I know little about this Bonneville and even less about wheel bearings. Is this something I should really be concerned about? I am about to move to a new state and need all the money I can get for the move. So I would rather not spend the $300. On the other hand, I do not want to get to my new place and then have something go terribly wrong with my car. Is this something I can hold off for a few thousand miles, or longer, or should I really be concerned about this? I have not noticed any noises or any major problems with the handling of the vehicle. This car is new to me so I do not know exactly what I should be listening or feeling for, but I have not noticed anything out of the ordinary. Any suggestions, help, or advice would be much appreciated. Thanks!
New Bonneville Enthusiast
PostPosted: Tue Feb 25, 2014 2:14 pm
I'd get it replaced. Are you at all mechanically inclined? It's not that hard to do yourself. I'd recommend you get a Timken bearing, Amazon has good prices on them. Most shops install poor quality (low price) or expensive, medium quality bearings. A Timken (high quality, reasonable price) hub online is around $100, then add labor.
PostPosted: Tue Feb 25, 2014 2:16 pm
Year and Trim: 2004 GTO
:withstupid: Ed beat me to it.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Tue Feb 25, 2014 2:24 pm
In the first couple years of owning my Bonne, my ABS started randomly activating during slow stops, so I had it scanned at the dealer and they told me it needed a new wheel bearing (the sensor is built in) and a new ABS controller. I opted to just unplug that bearing/sensor and disable the ABS entirely and the problem went away. Years later (a few months ago) I replaced that bearing just because I was replacing various wearable items in the front suspension, and guess what, full ABS functionality came back. The dealer tried to screw me into buying a $1200 ABS controller. So I feel your pain.
A wheel bearing physically falling apart or failing to rotate is pretty rare. Mostly, they start grinding, and I've known people to drive on grinding bearings for a really long time. I do know one person that had a bearing seize. It was grinding for a while, several months, and one day it was frozen solid when he tried to leave work. It got hot enough while he was driving that something melted and it locked up when it cooled off.
Wheel bearings are less intimidating than they sound to replace. But it takes a few hours if it's really corroded in there. I think the GXP has aluminum knuckles, so they might be pretty easy to remove, relatively. If you can do it yourself, I would if you can hear grinding, or if you jack that wheel up and there is wobble/play by hand.
$250 isn't super awful terrible, if it included a quality bearing, I guess. Though mechanics know how to get them out pretty easily. A bearing is what, $80? Ask yourself, is it worth $150 or whatever, to sit and wait for an hour or two, or spend at least that much time doing it yourself (and eventually realizing that pulling on it is getting you nowhere, and prying is barely fruitful, so you whack it on the side with a hammer and see that every hit moves it out a bit).
The likely true situation here is that you have time to get a bearing yourself, and arrange a free afternoon with some tools, and knock it out, saving you a nice wad of cash. I wouldn't ignore it forever though.
PostPosted: Tue Feb 25, 2014 3:11 pm
The bearings on these cars are self contained hub units. They will not (or should not), snap off unless the thing is so far out of lateral alignment in the hub race, OR the bearings are almost seized. However, stranger things happen. I've seen people with bad bearings on any GM FWD vehicle drive them for 50k, howling away with nothing more than poor fuel economy and the noise. The amount of lateral movement shouldn't be so much as to alter alignment enormously, but they are not technically "wrong" on that. Anything that alters your suspension geometry can cause out of alignment issues.
As mentioned above, they're fairly easy, one piece assemblies. Timken makes a pretty solid one. Buy it online and take to reputable shop. Shouldn't take more than an hour for them, and at ~$80/hr labor, figure another $80.
PostPosted: Tue Feb 25, 2014 11:38 pm
Thanks to everyone for the comments and suggestions. I think I will just hold off on it for the moment. Perhaps later down the road, no pun intended, I will buy one online and try to change in myself. Thanks again for the advice!
PostPosted: Wed Feb 26, 2014 1:06 am
I don't know that I would wait too long, especially if it does have side to side movement. But you don't need to do it tomorrow if that is what you're concerned about.
PostPosted: Wed Feb 26, 2014 1:30 am
2004 Bonneville GXP
second that don't wait too long.
bobgto65
PostPosted: Wed Feb 26, 2014 7:17 am
Allen head impact driver set
Hammer
Jack and jack stands
Torque wrench
Lug nut wrench
1 5/16" x 1/2" drive deep wall impact socket
Long 1/2" heavy duty socket handle and maybe a breaker bar
medium to large Torx bits
assortment of metric sockets and wrenches (I can't remember which though 10mm thru 15mm should cover it)
caliper grease
Brake cleaner spray
rags for wiping down the rotor.
I hope this helps and that somebody corrects me where I am wrong
great car. Wrecked
Burnt Bonny.
PostPosted: Wed Feb 26, 2014 12:03 pm
IIRC, you need a
19MM or 3/4" (19MM = 3/4") 1/2" drive socket for the lugnuts
34 MM 1/2" drive socket for the axle nut
15 MM 1/2" or 3/8" socket for the brake caliper
13 MM 3/8" Drive socket and extension for the hub bolts
1/2" Drive Ratchet
3/8" Drive Ratchet
Maybe a Cheater Pipe, depending on your strength/sockets.
Screwdriver to stick into the vanes of the rotor to keep it from spinning when you remove the axle nut.
Also: DON'T BREAK THE CALIPER TO KNUCKLE BOLTS, DON'T OVER TORQUE THEM. I broke one doing brakes on our GXP, and it was hell to find another one. They're a special shouldered bolt, and GM only had a few left. Mine had to come from NJ...
spoiledred, I think your list looks a lot more like a 92-99 list. 00+ is totally different. No torx or allen head bolts here.
PostPosted: Wed Feb 26, 2014 12:04 pm
Get a new axle nut, too. They're a few bucks, and they aren't normally supposed to be reused.
There are no new unread posts for this topic. Wheel Bearing?
mblaze
Thu Jul 16, 2009 9:50 pm
Wordski View the latest post
There are no new unread posts for this topic. Wheel Bearing/Hub Assembly
dpnewfie
20
8654
Sun Oct 24, 2010 5:39 pm
There are no new unread posts for this topic. Wheel bearing almost done, having some issues though..
20gxp04
Mon Mar 11, 2013 7:22 am
FasGP View the latest post
There are no new unread posts for this topic. Front Wheel Bearing
300sflyer
18
1523
Wed Dec 09, 2015 4:15 pm
300sflyer View the latest post
There are no new unread posts for this topic. Torrington Bearing
obis88
Fri Sep 26, 2008 4:53 pm
