It is currently Sun Jan 20, 2019 1:07 am
PostPosted: Fri Dec 07, 2012 5:53 pm
I've had this GXP for a couple months now and sometimes when I turn off the car the radio will keep playing even with the key out and the door open. I've had cars that will keep the radio on with the key out but only if the doors are closed and then once the door opens the everything will shut down. Is this something anyone else has seen? It's not too big a deal and not real bothersome although I was embarrassed the other day when I tried to get out of my car at work since my boss and another co-worker were in the parking lot and music was playing loudly coming from my car like I was showing off. I'm usually careful to turn it down once I get somewhere out of respect for other people but sometimes I just forget and that time I did. OOPS! It's really not that bothersome, I realize there are worse things that could be happening but if anyone knows why this is happening and if I shold be concerned about it, I would appreciate it. :dontknow:
(BTW, I've always wanted a GXP and I absolutly love everything about this car so far. Love the way it looks and drives. Also can't get enough of that N* sound, love love love it! It's been a few months and the novelty still hasn't worn off. I don't think it's going to either! Can't wait to start personalizing and making improvements/modifications.) :)
Lupe
05' GXP
PostPosted: Fri Dec 07, 2012 5:56 pm
My car does that occasionally, I think it's something with the connection that the door makes to tell the car it's open or not. Do you have the stock stereo? How do you normally get it to turn off?
PostPosted: Fri Dec 07, 2012 5:58 pm
Yes everything is still stock. I've just been shutting the radio off manually. The first time I thought it might kill my battery but it didn't. I assumed it just shut off automatically after a while like it does when the key is in, car is off and doors stay closed.
Lupe
05' GXP
PostPosted: Sat Dec 08, 2012 12:18 am
I think it'll turn off regardless after 10 minutes with the keys off like the interior lights do if you leave a door open.
PostPosted: Sat Dec 08, 2012 8:12 am
I had this exact issue. It is the "door actuator switch".
It was intermittent also.
Sometimes I would have to re-shut the door to get the radio off.
Part was $240 but luckily i still had my extended warranty
PostPosted: Sat Dec 08, 2012 9:57 pm
PM Harofreak00. He'll have what you need...
PostPosted: Mon Dec 10, 2012 11:00 am
Whoa $240??? That seems a bit much for something that hasn't been bothering me all that much yet. I may just live with it for a while... Thanks for the info guys! I'll check with harofreak if it gets worse. Or I wonder if in this case, would a stitch in time save nine?
Lupe
05' GXP
PostPosted: Mon Dec 10, 2012 1:11 pm
$20 for the part you need.
-Andrew-
PostPosted: Mon Dec 10, 2012 3:03 pm
Oh! Well that sounds much better. How hard is it to replace and where does it even go? Sorry, I'm not a mechanic but I try to dabble. My famous last words are usually, "oh yeah, that seems easy enough, I can do it!" LOL
Lupe
05' GXP
PostPosted: Mon Dec 10, 2012 8:19 pm
Fairly involved fix actually. You'll need to remove the door panel, the water shield and maybe even the window glass and glass track.
-Andrew-
PostPosted: Tue Dec 11, 2012 3:33 pm
Ok well that sounds like I'll have to get some help for all that, or pay someone to do it for me. I'll be in touch for the part. Thanks!
Lupe
05' GXP
PostPosted: Sat Aug 11, 2018 4:57 pm
Year and Trim: 2004 Buick Lesabre Limited
Gran Touring package
Can someone post the part number of this "door actuator switch"?
I have the same problem with my radio not shutting off and can't find this door actuator switch online.
PostPosted: Sun Aug 12, 2018 1:57 pm
if you open the passenger door, does it still stay on? that may narrow it to the drivers latch.
PostPosted: Sat Aug 18, 2018 10:57 pm
The switch is part of the door latch assembly and isn't available separately. Therefore, to get a part number, you need to specify which door it's for.
There are no new unread posts for this topic. Gm Lux Navigation Radio
ck2001
Sat Oct 31, 2009 1:24 pm
There are no new unread posts for this topic. Sirius/XM Radio in GXP
PontiacFan
Tue Nov 04, 2014 12:34 am
bobgto65 View the latest post
There are no new unread posts for this topic. Radio display led's burnt out again.
FrankAR15
Mon Oct 13, 2014 11:02 pm
There are no new unread posts for this topic. Aftermarket Radio Installation
JDArbital
Thu May 14, 2015 10:46 am
There are no new unread posts for this topic. XM radio issue - No signal
Juggernaught
17
2081
Sat Oct 31, 2015 10:11 pm
ddalder View the latest post
