It is currently Tue Apr 16, 2024 2:44 pm
PostPosted: Tue Mar 06, 2012 12:32 pm
Year and Trim: 2004 GXP
I've seen some guys on here complaining about the fact that OEM front motor mounts suck, so I decided to make a hockey puck motor mount for a GXP. The tools you will need are a hack saw, 9/16" drill bit, drill, welder and a protractor. Supplies you will need are 5 hockey pucks, 1/2" threaded rod, 2 1/2" locking nuts, 2 1/2" fender washers. I started out by cutting a hockey puck in half horizontally, then cutting one half of that in half horizontally from the top corner to the bottom corner so you end up with a round wedge that is 1/2" tall on one end and hypothetically 0" tall on the other end. Then I drilled a 9/16" hole in the center of the 4 remaining hockey pucks. Then I drilled a 9/16" hole on the wedge shaped hockey puck slightly offset towards the smaller edge of the hockey puck so that the hole is perpendicular to the cut surface of the hockey puck. I then made two notches in the center of the threaded rod so I could bend the rod to a 10° and welded it solid. I then slid the 4 uncut hockey pucks onto one half of the threaded rod and the wedge hockey puck onto the other end of the threaded rod so the uncut side is touching the other hockey pucks. I then held the old OEM motor mount next the hockey puck mount and cut the threaded rod on both ends to the appropriate length and reinstalled the new hockey puck mount. It was a little chore to reinstall the mount, do to it being very ridged but with a little love it will go. This is hopefully the first and last front motor mount I install.
Seth
RogueSSEi wrote:
Bet she'll stop on a dime and give you 3 pennies back!
PostPosted: Tue Mar 06, 2012 1:09 pm
I'm interested to see how this works out. It has been talked about in the past. About time for a permanent solution for GXP owners.
88 Cutlass Ciera Brougham International | 120k mi | White w/ Dk Claret Int. | Roller to be S2 L67/4T65E-HD | 1 of ~5100 3.8 FE3 Int'l series
05 Acura RL | 155K mi | Carbon Grey Pearl w/Ebony Int. | The Super-Hooptie Daily
James May wrote:
Hello.
PostPosted: Tue Mar 06, 2012 1:17 pm
The car is official NHL authorized now. :)
2007 Chrysler Town & Country Limited: Sold to neighbor
2003 Chevrolet Suburban 2500: Doeskin Tan - 8.1L Big Block... new plow truck
PostPosted: Tue Mar 06, 2012 1:42 pm
Nice Job! I know this has been an issue around the forum for awhile.
Eric
A few mods..
PostPosted: Tue Mar 06, 2012 4:13 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
It would be good to see if this holds up. I personally shyed away from this setup because I wasn't confident on the remaining strength of a bent or welded Grade 8 threaded rod.
PostPosted: Tue Mar 06, 2012 8:08 pm
I figured for $9 I would give it a try
Seth
PostPosted: Tue Mar 06, 2012 9:59 pm
Yup, this!
Good work sir.
J Wikoff wrote:
It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
PostPosted: Mon Mar 26, 2012 2:30 pm
This might not be a long enough test yet, but 2,500 miles with a few WOT drives and she's not showing any signs of failure yet..
Seth
PostPosted: Mon Mar 26, 2012 2:32 pm
Good to hear.
PostPosted: Sun Apr 15, 2012 3:45 am
Where are you finding hockey pucks so cheap? Best I have seen locally is $5 each.
PostPosted: Sun Apr 15, 2012 8:32 pm
Mills fleet farm $1 each
Seth
There are no new unread posts for this topic. The new and improved hockey puck mount
sethjamesrimrodt
Sat Jun 09, 2012 11:30 pm
sethjamesrimrodt View the latest post
There are no new unread posts for this topic. Front Motor mount replacement revisited
bobc997615
Sat Jun 01, 2013 11:34 pm
repinS View the latest post
There are no new unread posts for this topic. GXP Motor mount woes..
GXP_vince
15
2919
Mon Apr 01, 2013 2:48 pm
There are no new unread posts for this topic. Northstar Performance motor mount
NashvilleGXP243
Mon Dec 21, 2015 12:12 am
NashvilleGXP243
Mon Dec 21, 2015 2:22 am
havoc1482 View the latest post
