It is currently Thu Dec 13, 2018 9:44 am
PostPosted: Sat Nov 12, 2011 10:30 am
Year and Trim: 2005 Pontiac Bonneville Gxp
Just needed feed back on if the exhaust was magnaflow of flowmasters.
PostPosted: Sat Nov 12, 2011 10:57 am
Neither! The stock GXP has a Corsa exhaust system.
J Wikoff wrote:
It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
PostPosted: Sat Nov 12, 2011 11:55 am
That's pretty cool, so Corsa exhaust is better the other two correct. Also where to get them new if needed.
PostPosted: Sat Nov 12, 2011 12:42 pm
I wouldn't go as far as to say that one is better than the other but if you want to change the tone of the exhaust, then those that you listed are some pretty good alternatives.
PostPosted: Sat Nov 12, 2011 12:50 pm
Wow you have 163,000 miles on that northstar motor, have you had any serious problems yet?
PostPosted: Sat Nov 12, 2011 1:11 pm
Nothing major engine wise; replaced the oil cooler lines, valve cover gaskets and one coil. Outside of that; I just had the trans rebuilt and I'm about to change the front motor mount for the third time.
PostPosted: Sat Nov 12, 2011 1:13 pm
Ummm, the stock GXP exhaust is made by Bosal, an OE supplier of exhaust pieces. It's the same company that made the exhaust on the SSEi's, and most other GM stuff.
Neither magnaflow nor flowmaster make exhausts for OE Manufacturers. They sell aftermarket parts for vehicles, but no car rolls off the assembly line with parts made by either company.
PostPosted: Sat Nov 12, 2011 1:38 pm
Your right Ed.
I don't know why I was thinking Corsa. :banghead:
PostPosted: Sat Nov 12, 2011 1:42 pm
yea was looking at the corsa exhaust and there sport systems are nice but they are expensive.
PostPosted: Sun Nov 13, 2011 2:34 am
Moderator
Moderator
Year and Trim: 09 G8 GT
Yes, the stock system is made by Bosal.
As for Corsa systems for Bonneville GXP, you will need Corsa Part number 14151 for Cadillac DTS. Count on shortening the main pipe just behind the cat, as well as the length of pipe where the exhaust tips attached. You also may have to bend the Y-pipe slightly to get everything to fit. And even then, your tips will stick out pretty far. I also had my muffler shop add an extra hanger to the Y-pipe for added stiffness so that the tips would not contact the bumper when they bounce around.
Position the hangers accordingly, and you will know where to cut/modify. Also, don't count on having a valid Corsa warranty after this :wink: For me, the result was still totally worth it. It sounds fantastic and is loud (all mufflers are straight-through), and there is ZERO drone whatsoever on the highway or when cruising.
Video: http://www.youtube.com/watch?v=8rtrmKKkXOc
PostPosted: Sun Nov 13, 2011 3:21 am
Yea buddy full-cat back that sounds great. Nice car and video dude. I think i m going to wait till i get some cash saved up and get the exhaust. But Ive been trying to decide on if i want the R1 concepts brake-rotor setup on eBay or go with hawks ceramic brakes and a nice drilled-slotted rotor.
PostPosted: Sun Nov 13, 2011 3:52 pm
Jerry your car sounds amazing!
And YoungGovna, definitely go with the Hawk Ceramic Pads, but get a slotted ONLY rotor. Trust me, they rock!
"Penelope" - 2003 SLE - 180k Miles
"Sydney" - 2000 Honda S2000 - 59k miles
PostPosted: Sun Nov 13, 2011 4:38 pm
:withstupid:
Just did this on mine, amazing difference...No need for drilled rotors, slotted are just fine, and less of a risk of breaking the rotors as well. :btruestory:
92 Bonneville SSE | L67/4T60E | 70K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 175k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 180K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 234k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 178k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 200K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 139k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
There are no new unread posts for this topic. GXP exhaust and SSEi exhaust interchangeable??
sseilmnop
Tue Sep 13, 2016 2:51 pm
sseilmnop View the latest post
There are no new unread posts for this topic. exhaust question?
gxp937
Sat Jun 07, 2008 12:47 pm
There are no new unread posts for this topic. Minor issues 05 bonnie
Froman03
Mon Nov 06, 2017 9:37 am
Froman03 View the latest post
There are no new unread posts for this topic. Po171 & Po174 mystery 05 Bonnie Gxp
bonniegxp_97
11
1451
Mon Feb 29, 2016 9:24 pm
bonniegxp_97 View the latest post
There are no new unread posts for this topic. is it normal to have water condensation exhaust?
nickburgundy
Wed May 09, 2012 7:25 pm
cron
