It is currently Fri Mar 05, 2021 7:22 pm
 Post subject: Gas Tank Rust
PostPosted: Tue Sep 06, 2011 1:38 pm
Year and Trim: 2010 Dodge Ram SLT Big Horn
1995 Chevy Camaro Z28
Hey guys, just bought my '04 GXP with 72k on it, love the car! Having owned previous Bonnevilles, I know there is an issue with the rear 1/4 panel rusting due to the gas tank, and I was wondering what is the best sealant for closing off that seam from water entry? Is there some type of epoxy or caulking that works best? Also, I noticed a small hole almost right under the gas cap, should that also be filled with some kind of sealant?
I would like to keep this car for awhile and avoid the dreaded rust issue. Thanks for the help.
In My Garage:
1995 Camaro Z28 - LT1 w/ 6-speed, Magnaflow Exhaust, Moroso Cold Air Inake, Powerstop drilled/slotted rotors and ceramic pads, Z06 Chrome Wheels, Founders Performance Strut Tower Brace (Work in Progress)
2010 Dodge Ram SLT Big Horn Edition Quad Cab - 5.7L Hemi, 390HP, 4x4, Daily Driver
Past Vehicles:
1989 Acura Legend - 'Tank'
1999 Dodge Dakota Ext. Cab - 'Bulldog'
2004 Bonneville GXP - 'Red Demon' - Already Missed
***Showed up expecting a battle, left with a laugh***
 Post subject: Re: Gas Tank Rust
PostPosted: Tue Sep 06, 2011 1:40 pm
Welcome to the club.
Don't forget to post photos of your car.
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
PostPosted: Tue Sep 06, 2011 1:57 pm
Welcome.
It's not because of the gas tank, and it's due to water leaking in the trunk behind it and causing issues. About the only thing you can do is keep the car leak-free. Don't fill that hole in the bottom, that's to allow the water to drain out when you drive in the rain, etc.
Some have filled the gaps with RTV or other sealants, etc. It's worth a shot. There's nothing that anyone on here recommends specifically.
PostPosted: Mon Sep 12, 2011 9:25 pm
The hole under your gas cap is a drain hole for when you overflow your gas tank. Don't fill that one. Do a search for a thread called, "help, my car's taking on water" or something very similar, there is an amazing writeup including pics.
PostPosted: Fri Sep 23, 2011 10:59 am
The only way to really fix it is to take it to a body shop and have them fix it. In the process, they will remove the foam absorber/insulator behind the metal which retains the water/gas, which is the main culprit in the rust around that gas tank fill area. It affects most GM FWD cars.
Even after the fix, it isn't 100% gauranteed NOT to re-rust, but at least the chances are in your favor.
2003 Chevrolet Suburban 2500: Doeskin Tan - new plow truck
PostPosted: Fri Sep 23, 2011 1:31 pm
Moderator
Moderator
Year and Trim: 09 G8 GT
On a related note, I saw my first pinhole-sized bubble yesterday :(
PostPosted: Fri Sep 23, 2011 2:16 pm
Year and Trim: 1993 Bonneville SSE
Yeah those rust bubbles are showing on mine too! :banghead: Not sure how to take care of it. But im sure ill think of something. Good luck!
-Zach
There are no new unread posts for this topic. Rust on rotors
CincyGXP
Sun Sep 14, 2008 11:46 pm
This topic is locked, you cannot edit posts or make further replies. Rust on rotors
CincyGXP
Sat Sep 06, 2008 6:03 am
CincyGXP View the latest post
There are no new unread posts for this topic. Gas Filler Rust Repair
alberta3
Wed Jun 04, 2014 10:43 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Windshield Washer tank replacement
jimGXP04
Thu Feb 01, 2018 7:53 pm
JEFFSSSEI View the latest post
There are no new unread posts for this topic. Coolant reservoir tank level
FrankAR15
Sat Jan 02, 2016 9:20 am
FrankAR15 View the latest post
