It is currently Tue Apr 16, 2024 6:25 am
PostPosted: Sat May 21, 2011 1:45 pm
Year and Trim: 2004 GXP
I notice that my a/c has begun to cycle between on and off. I have the automatic heating and cooling. Hitting the a/c button does not override the a/c being in the Off position. I started noticing that it's now more in the OFF position than the ON position.
Is there a leak of refrigerant and the compressor just keeps shouting off?
Anybody have any ideas?
PostPosted: Sun May 22, 2011 7:15 pm
The AC system has a low pressure cutout switch which keeps the AC compressor from running with a low refrigerant charge. This prevents the compressor from being trashed if the refrigerant is low. You really need a set of AC gauges to determine if the R134a charge is low. If it is low you need to find the source of the leak and fix it before adding refrigerant. Unless you have the proper tools this is pretty much a job for a pro. They have the tools to find a leak, repair it and recharge the AC system to the proper charge of refrigerant.
Good luck!
There are no new unread posts for this topic. air conditioner
dutchman
15
4227
Sat Mar 09, 2013 8:27 am
J Wikoff View the latest post
There are no new unread posts for this topic. Air Conditioner not cycling properly
rwebb616
Thu Dec 14, 2023 5:40 am
yellrealistic View the latest post
There are no new unread posts for this topic. automatic level control gone whacky
rottyluvr
Fri Apr 19, 2013 8:20 pm
There are no new unread posts for this topic. Rear Automatic Suspension problem
tobbyjl
11
7833
Sun Dec 25, 2016 10:49 am
Kadeas View the latest post
There are no new unread posts for this topic. HVAC blower system
hobbypro
11
2239
Thu Feb 12, 2015 12:08 am
