It is currently Sat Jun 23, 2018 9:00 pm
 Post subject: DIC issues
PostPosted: Sun Mar 27, 2011 10:21 am
Year and Trim: 2005 diamond white GXP
Had a remote start put on the car 6 months ago but not sure if it is related to these issues. I am not using the factory remotes fobs anymore, new ones came with the remote start. I have programmed the memory seat for me. Ok, here are some of the wierd observations: 1) The drivers seat goes to some wierd position that I have NOT set when removing the key ( I then hit the memory 1 position and it sets correctly). 2) I have turned off the right side mirror automatically tilting down for backing up in the DIC but it has started doing it again without me changing anything 3) I had a flat tire a few weeks ago but the "low tire sensor" warning never came up. Had the tire fixed and now it comes up every time I drive the car, I can clear it then I am good for the rest of the mission. These are minor annoyances, had anyone else experienced these things? And, are they related to the DIC?
 Post subject: Re: DIC issues
PostPosted: Sun Mar 27, 2011 12:13 pm
Removing the key probably sets off the "Exit" postition. Get your seat into your normal position and press and hold the "Exit" button on the Memory Controls until it beeps. That way the exit position will be the same as your normal position.
Ours does the mirror thing too, even w/ it off. I have NFC why.
Have you scrolled to the Tire Pressure menu and reset that? You need to press and hold RESET until it says NORMAL. Might want to check all 4 pressures and make sure they're within 2 PSI.
PostPosted: Sun Mar 27, 2011 12:22 pm
Year and Trim: 2006 Cadillac STS-V, 2004 Pontiac GTO
In addition to above, if this happened after the remote start was installed, I wonder if a wire that feeds into the cluster feed may have been nicked during installation. Electronics and harnesses in these cars can be very sensitive, so when someone is splicing in aftermarket equipment into the harness, it can create different resistances within the circuit, shorts, opens, and even voltage surges when power is running through them.
PostPosted: Sun Mar 27, 2011 12:27 pm
To be fair, I guess we do have a remote start in our GXP too, but we never got remotes for it and I haven't gotten around to it either...
PostPosted: Wed Jun 01, 2011 8:57 pm
When I bought my Bonnie it had an aftermarket starter in it as well, with one starter keyfob. I replaced both OEM keyfobs and use the starter keyfob for just that, starting the car. The OEM's are linked to Driver 1 and 2 (I had to have them programmed at the dealer but I bought them online) and control a lot more than just the seat.
The 'move seat to exit position' on key removal is programmable within the DIC. You would see the benefit of this if you used the OEM fobs - seat moves to an easy to exit position when you're ready to get out; moves back to driver 1 or 2 position when OEM fob is used to unlock door when ready to drive again. The fob/DIC programming remembers a lot of different settings from seats, outside mirrors, radio (including volume, stations and EQ settings), A/C, etc.
2005 Bonneville GXP (SOLD), Crimson Red Tintcoat
Other Rides: 2009 Solstice GXP Coupe #606, Cool (Liquid Silver) | 2007 BMW 750Li, Toledo Blue Metallic
Past Rides: 2007 Grand Prix GXP, Red Jewel Tintcoat | 2004 Grand Prix GT2, Fusion Orange | 2002 Bonneville SSEi, Black | 1999 Regal GS, Black | 1997 Bonneville SSE, Blue-Green
1994 Cutlass Supreme S, Turquoise | 1989 Cutlass Supreme IS, Bright Red | 1988 GMC Sierra 1500, Dark Red | 1982 Regal Sport Coupe, Maroon/Silver | 1975 LeSabre, Beige
Wife's Chariot: 2006 Buick Rainier CXL, Red Jewel Tintcoat
PostPosted: Wed Jun 01, 2011 10:36 pm
Yeah, the exit position thing is great till someone (usually my mother) is in the backseat and they get crushed because something in the system is goofed up.
PostPosted: Wed Jun 15, 2011 8:57 pm
Year and Trim: Currently searching for a Bonneville...
How do you get the car to move to the exit position when the key is removed? I've never seen that option in the DIC, and my seat does a whole lot of nothing when I take the key out.
Inferno Red 2009 Dodge Caliber SRT-4 125k
PostPosted: Wed Jun 15, 2011 9:54 pm
You know what, I may have mispoken. I just went back to the manual and I guess you can set it in the DIC to move either to your memory position or the exit position when pushing the button to unlock the doors. It apparently does not go to the exit position when you pull the key; you have to push the exit button. I must have it confused with another car because I know I've been in a car that does move it to exit when you shut it off. But not our Bonnies. Sorry for the confusion. :roll:
PostPosted: Wed Jun 15, 2011 10:06 pm
you may wanna call ghost busters!!! lol j/k
2005 Bonneville GXP Fully Loaded
There are no new unread posts for this topic. Key issues with the GXP
crash93ssei
14
3687
Sun Aug 05, 2012 9:36 pm
yonkerse View the latest post
There are no new unread posts for this topic. LX5 V6 issues?
jcweis1
Thu Apr 09, 2015 7:45 pm
There are no new unread posts for this topic. Quality Issues!
Gagger14
11
1772
Sun Jan 15, 2012 2:51 am
There are no new unread posts for this topic. May have found my issues. what do you think?
tylerlp0
19
2152
Sat Jan 04, 2014 12:22 am
There are no new unread posts for this topic. Electrical issues
slago1205
Thu Mar 20, 2014 12:11 pm
Archon View the latest post
