It is currently Tue Apr 16, 2024 3:03 pm
PostPosted: Sat Sep 12, 2009 10:58 am
I've got a crazy situation going on with the GXP. Yesterday I drove from Dallas to Baton Rouge. Stopped 1/2 way for gas. I noticed that the gas gauge had been stuck at 1/3 even though it took 16 gallons of fuel. After I gassed it up, the gauge still reads 1/3 tank AND the trans started shifting very hard. I drove it the rest of the way with the trans shifting hard.
This morning the car won't start it will just sputter a bit. Then I looked at the gauges and the temp says 200 degrees??! Car is dead cold. So I scanned the PCM, and PCM says coolant temp is 212 and outside air is 102 (its about 75 degrees outside). I checked all the obvious stuff, looked for loose wiring, checked the pcm connection etc, but I can't find anything amiss.
If anyone has seen this or has ideas, please let me know. I'm supposted to be at work in Dallas tomorrow, so this is going to be a huge pain if I can't get the car started.
I checked trouble codes, and there were no stored trouble codes, but the following pended codes were listed:
P0412 P0418 P0443 P0449
Thanks in advance for any help!
2005 GXP Silver, Gutted Airbox, K&N filter, 14.61 @ 94.31 mph.
1987 t-bird 2.3 turbo, stock motor with home-ported head, big turbo, big exhaust, alky injection, a bunch of other little stuff, 13.65 @ 102 on radials.
Last edited by 2.3 turbocoupe on Mon Sep 14, 2009 2:36 pm, edited 1 time in total.
PostPosted: Sat Sep 12, 2009 11:06 am
Year and Trim: 2004 Volvo S60
The only thing I can suggest as an idea is unplug the battery for a few minutes and let the computer clear, then try again. Hopefully a gearhead will chime in with suggestions...
PostPosted: Sat Sep 12, 2009 11:53 am
Wow, sometimes try the obvious, thanks chillin. I disconnected the battery for about 5 minutes. Reconnected and both the gas gauge and coolant gauges were reading correctly! Then she started right up! And the trans is shifting fine!
However... it was running on a high idle and the ac would not come on (just blowing hot air). So I shut it off and restarted. Idle was normal but no a/c. So maybe there is still some issue, but its running and driving so I will try driving some more to see if its ok.
Thanks!
PostPosted: Sat Sep 12, 2009 1:39 pm
Yeah I'd be careful, whatever caused the issue is probably still lurking. This might do the trick to get you home. I'd suggest further diagnostics and driving it easily until you figure out the real issue. Repeat step if problem occurs again to get home. Glad I could help.
PostPosted: Sat Sep 12, 2009 9:25 pm
Check the battery cables and battery grounds. Make sure there is no corrosion, and the connections are good and tight. Consider using some dielectric grease to prevent oxidation. Then check the ground connections for the PCM.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
PostPosted: Sat Sep 12, 2009 11:18 pm
I was thinking to tell him the same, but what stopped me is that the 00+ has the battery under the back seat IIRC, shouldn't be such a problem being there (of course, still cannot hurt to check)
Last edited by ChilinMichael on Sat Sep 12, 2009 11:18 pm, edited 1 time in total.
PostPosted: Sun Sep 13, 2009 12:30 am
In fact, if our esteemed members can be believed, there is a problem especially with the body ground for the battery in the newer models with the battery under the rear seat. (I only know this from reading others' posts - have yet to make the leap to 2000+)
PostPosted: Sun Sep 13, 2009 2:29 am
Hopefully not, but it might be a bad PCM. If you can find such a newer car at the wrecker a salvaged PCM is pretty cheap. You could carry it as a spare seeing how you make some long distance trips
great car. Wrecked
Burnt Bonny.
PostPosted: Sun Sep 13, 2009 9:57 am
The bolt for the grounding strap can bet pretty rusty and corroded. It would have been a better design had the threads in the floor pan not gone all the way through to the outside. Sometimes, the vent tubes from the battery may come loose, allowing the battery vapors to get trapped under the seat and start to corrode connects, and the floor pan itself.
A PCM would have to be programmed for your car's VIN and features, as well as the Pass Key system, for it to work.
PostPosted: Mon Sep 14, 2009 10:06 am
Thanks all. I made it home without incident yesterday. Car drove perfectly except for the lack of A/C. I'll check the grounds when I get a chance, but I think it must be pcm related or ???. That is really a trip that the PCM thought a dead cold engine had high coolant temp. Almost like it needed a reboot to wake up. Seems like the sensor readings froze to a value and did not change, and that started all the problems. And yet I never got a check engine light, and the engine ran fine until I tried to start it the next morning. In my original email, I didn't even mention the fact that when I was coming into Baton Rouge during rush hour, I got stuck in a traffic jam, and a little bit of steam was coming from under the hood. At that time, I figured the trans was dying. I heard a few hising sounds, then I saw a poof of steam or something come out of the a/c vents, so I turned off the ac. Then a few minutes later when I tried turning it back on, it did not cool, so I left it off.
Regarding the a/c, I checked last night and the compressor is running, the low side is at 27 lbs when loaded, and one of the lines is extremely cold as I would expect with a healthy a/c. But it won't cool off in the car. The air is just slightly less than ambient. Seems like it must be something in the temp control unit or whatever regulates the temp. During the drive, I tried every variation of climate control settings to wake up the a/c, but to no avail.
All I got to say is this is some weird sh......stuff.
Last edited by 2.3 turbocoupe on Mon Sep 14, 2009 10:08 am, edited 1 time in total.
PostPosted: Mon Sep 14, 2009 2:43 pm
After doing some research, I found that the low-pressure side should be around 40 with the compressor running. I added some R134, low side pressure is 38 and she's blowing cold. Again, this is all pretty crazy and I really don't understand what happened. Somehow the ac system released freon very quickly, and yet its holding fine now.
PostPosted: Mon Sep 14, 2009 3:16 pm
Low pressure should be around 44psi under load. Go get you another can of R134 and dump it in there. Please keep in mind though; do not let the LP go higher than 44psi. An easy way to ensure this doesn't happen is to buy a can with the gauge on it. :wink:
J Wikoff wrote:
It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
PostPosted: Mon Sep 14, 2009 9:09 pm
Thanks DP, I'll do that.
PostPosted: Tue Sep 15, 2009 12:58 am
The reason why it was running funny at first was because the process of removing the battery terminals is considered an idle re-learn. Basically it's like re-booting your home PC. It clears the PCM of all the bugs and learned tendencies it's picked up over time and starts at a base, fresh default. There is a complete idle re-learn driving cycle for GM's at www.OBDII.com .
My suspicion though is that if the problem came up once, you haven't fixed the problem, it'll come back again. If so, we can go through the methodology behind the systems driving those codes and steps for troubleshooting those codes above, or whatever DTC's pop up.
2007 Chrysler Town & Country Limited: Sold to neighbor
2003 Chevrolet Suburban 2500: Doeskin Tan - 8.1L Big Block... new plow truck
There are no new unread posts for this topic. car wont start
excessive81
14
2131
Fri Jun 21, 2013 4:56 pm
There are no new unread posts for this topic. Just bought an STS now it wont start
smittyingr
Sat Dec 22, 2012 3:49 pm
smittyingr View the latest post
There are no new unread posts for this topic. Replaced Plenum boot... wont start
bigmoney9161
Wed Sep 12, 2018 12:05 pm
There are no new unread posts for this topic. Auto Start Tachometer wire North Start
zigger21
Mon Sep 13, 2010 12:18 am
There are no new unread posts for this topic. New home for my GXP
1970GTO455
Thu Jun 27, 2019 10:05 am
1970GTO455 View the latest post
