It is currently Mon Feb 18, 2019 8:27 pm
Post new topic Reply to topic  [ 295 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15
 Post subject: Re: Fog Lights?
PostPosted: Sun Dec 11, 2016 4:05 am
Year and Trim: 2005 Bonneville GXP (Bone Stock)
I've already converted the low beams to HID and am very happy. I'm going to change the hi and fogs now and am reading about the fog kits having an H3 or H3C version. From what Ive read the difference is a matter of how the leads are attached. Anyone know if the H3C would fit better, or is this really not an issue?
PostPosted: Sun Dec 11, 2016 9:55 am
Year and Trim: 01 SLE
From what I understand, no. Though you may wish the H3C was oriented sideways because the filament is orientated sideways compared to the H3. Because of the arc location it puts out less light but is ridiculously expensive and is known to explode in less than a year. I'd stick with the H3 myself but then I have no inclination to convert to HID at all.
Maybe someone else has actual experience with the H3C tho.
01 Bonneville SLE
PostPosted: Thu Dec 22, 2016 1:39 am
When replacing the fogs do they just twist out or does any part of the housing need removed first?
PostPosted: Thu Dec 22, 2016 11:55 am
The little metal clip on the housing needs to be squeezed together to allow it to swing away from the housing.
PostPosted: Mon Dec 26, 2016 10:46 pm
I finally installed my HID fog lights today. Installation was straight forward after I figured out that I had to use the old fog light caps as an "adapter" between the wiring harness and the new ballast. My thanks again to everyone who contributed to this thread.
2005 Pontiac Bonneville GXP Greystone
PostPosted: Wed Jan 04, 2017 1:47 pm
Since I started using my new fog lights, I've noticed some different behavior concerning the auto head lights. This morning on the way to work, it was a little foggy, so I turned on the fog lights and of course the headlights were on. However, if I turned the fog lights off then the auto headlights would also turn off. If I turned the fogs back on, then the auto headlights would immediately come back on. It seems the fog lights are turning on the auto headlights and not the other way around? Is this normal behavior? Thanks!
PostPosted: Sat Jan 07, 2017 1:56 am
In order for the fogs to be on, either the parking lights or headlights HAVE to be on. So in ALC mode, by turning on the fogs, it is commanding on/off the headlights also.
PostPosted: Thu Jan 12, 2017 12:40 am
300sflyer wrote:
Here are some more pictures, with just the parking and fog lights on. They are every bit as bright as the stock H3s, if not more so. As long as they do not burn out, I'm happy. :banana:
So are these HID or LED bulbs?
PostPosted: Mon Jan 16, 2017 11:47 am
Year and Trim: 2004 GXP
2003 SLE [SOLD]
They are HID bulbs. I bought the kit from http://lumenshid.com/
PostPosted: Mon Jan 16, 2017 11:59 am
Oh, don't worry, they're brighter. Any HID will have more lumen output than a halogen equivalent.
A regular H3 bulb will have around 1,500 lumens and be 3,100k. If this is is a 35w kit, I wouldn't be surprised if those are nearly twice the lumen output.
PostPosted: Mon Jan 16, 2017 12:05 pm
2003 SLE [SOLD]
This kit actually claims they are at least 3 times brighter. They are really good for winter driving at night too, as they reflect off of the snow. http://lumenshid.com/hid.html
PostPosted: Mon Jan 16, 2017 1:54 pm
I think 3x is kinda stretching it. Safely I would say at least twice. Most 35w kits pretty much double up lumen output. This isn't their "proprietary kit" They're all pretty much the same universal stuff be it Morimoto, DDM, this place, etc...
PostPosted: Mon Jan 16, 2017 2:02 pm
2003 SLE [SOLD]
2 or 3 doesn't really matter to me. All I know is that they are FAR brighter than the original H3s, and driving at night now is a whole new experience when they are on. :banana:
One thing I will say is that they need their own specific ground. Trying to piggy back the ground wire onto another connection, does not work well.
PostPosted: Mon Jun 05, 2017 5:33 am
Year and Trim: 2013 Ford Explorer
I put LED fogs kit by OPT7 in my 2008 Pontiac G8 GT and they perform wonderfully.
https://www.bestadvisor.com/led-fog-lights
They come on instantly, unlike the HIDs I used to have, and they produce more light.
Doesn't get hot and water resistant which is great for the Miami weather. If someone still doing research, I would recommend them without a doubt.
PostPosted: Thu Jun 22, 2017 3:22 pm
I love LED's, especially as their technology is advancing quickly, but two things;
1) They list brightness as 3,500... 3,500 what? Lumen? Horsepower? Spoons?
2) It is a fan cooled unit in that base. Where the fog lights are located in the car are prone to moisture and or even splashed water slush, etc... I predict a short fan life, which then will deteriorate the actual bulb life.
There are no new unread posts for this topic. blinglights fog lights
excessive81
Thu Apr 25, 2013 3:12 pm
repinS View the latest post
There are no new unread posts for this topic. replacing fog lights
VAbonnyGXP
Sat Mar 26, 2011 9:07 pm
Bvill_GXP View the latest post
There are no new unread posts for this topic. Do GXP tail lights delaminate?
maxi426
Wed Aug 30, 2017 10:51 am
There are no new unread posts for this topic. Replacing button lights
05joenov
Sun Sep 13, 2015 11:40 pm
There are no new unread posts for this topic. Daytime running lights
sextrosgxp
Sun Oct 07, 2012 1:23 pm
sextrosgxp View the latest post
