It is currently Tue Oct 26, 2021 9:21 pm
PostPosted: Fri Aug 27, 2021 2:27 pm
Year and Trim: 2004 Bonneville SLE
Car is a 2004 Bonneville SLE with On-Star Hi everyone,I have a unique problem,I have installed a Alpine ute-62-bt hu using a PAC rp3-gm13 data-bus interface (Non-Onstar interface ) got everything wired up after some modification of the dash cavity.. and now my dual climate control will not work nor will the display light up, so i pulled the HU out and checked the factory wiring harness and the was a purple small wire that had been cut while i was cutting some of the cavity out to fit the HU in. i reconnected that wire and still no climate control..my air-conditioner blows all the time whenever i turn my car on...I have checked all the fuses and none are blowin...i did noticed that the back seat fuse box has a relay(no.51- Interior Lamps) that is running hot to the touch I pulled it and switched it out and it still runs hot I can`t remember what it controls at the moment, but this is puzzling....and i have another climate control module that i swapped out and still the same is there a connection in the upper dash that i could have pulled alose that is stopping the climate control from getting power? also my front door lights don`t work either the courttesy lights on the doors,the other interior lights work when you open the doors
PostPosted: Sat Aug 28, 2021 4:23 pm
anyone know if the climate control is tied into the factory HU? or is it seperate on its on circuit,if so it has to be switched through the IGN circuit
PostPosted: Thu Sep 02, 2021 10:20 pm
The head unit and it are tied together on the DataBus, but not otherwise as far as I am aware....the climate control does communicate with the IPM (instrument Panel Module) as well....if you cut a wire, did you check both fuse boxes, (hood and under back seat)? Is it possible you might have cut another wire or shorted something out during install?
3.8L V6 SC, 180*T (Drilled),
Custom PCM w/Perf Shift,
SLP Ceramic Coated Headers,
Thrasher Cold Air Intake,
PostPosted: Fri Sep 10, 2021 2:50 am
Yes I did check both fuse boxes,and yeah I did cut one wire that I fixed ,but there was another wire that I cut but it did not look cut but it was and the problem,it was hanging on by the insulation but inside the insulation the wire was cut so it was fixed... now everything works like its suppose to. :bwoohoo:
PostPosted: Thu Sep 16, 2021 11:41 pm
Glad You finally got it sorted out...pesky little broken/cut wires aren't they.
There are no new unread posts for this topic. Aftermarket Radio Installed - New Problem w/Climate Control
96LSS
Mon Oct 13, 2008 4:32 pm
There are no new unread posts for this topic. Aftermarket deck causes problems with climate control
bkwoods
Fri Dec 30, 2011 11:00 pm
bkwoods View the latest post
There are no new unread posts for this topic. Climate Control
Ragsdale
Sat Aug 16, 2008 5:36 pm
Ragsdale View the latest post
There are no new unread posts for this topic. Replaced radio no Climate control
Phantom
Tue Jan 17, 2012 3:56 pm
Phantom View the latest post
There are no new unread posts for this topic. My 2000 Bonneville Climate Control Won't Work
KevinMcQ4367
Sat Dec 15, 2012 8:56 pm
Moy View the latest post
