It is currently Wed Apr 24, 2019 8:44 pm
 Post subject: Chime issue
PostPosted: Mon Aug 13, 2018 2:31 am
Year and Trim: '03 SLE Silver/Charcoal
A few months ago the Display and the Chimes of the factory head unit quit working. Audio from the radio is good minus the left door speaker...
Thinking that it was the head unit itself, I swapped in my Android head unit from my Yukon into the Bonneville ( I kinda wanted to do this anyway) The chimes worked in the Yukon, but in the Bonneville they do not. So I am not troubleshooting this minor issue.
I have not done anything yet but determine that I have no audio from the driver door. Its been too *dang* hot to spend hours out there under the dash...
Oddly enough I do have Onstar audio if I push the button and i did check the module's volume for the chime.
Am I overlooking something simple like a fuse? Or do I start toning out wires looking for breaks?
On another note why does a 2003 have a "reverse" wire feeding into the factory radio? I noticed this and connected it to my head unit and when I shift into reverse it activates the backup cam it it was installed that is... This was barely thought of at the time the car was manufactured... And thought it was interesting...
my head unit also has 2 direct inputs for steering wheel controls that measures resistance to determine the button, is there a connection to the harness that I can tie these into or do I still need the steering wheel control module (yukon does not have steering wheel controls so I did not have this module
2002 SLE "Frankenbonnie" 02 engine, 04 transmission, and a 03 PCM to make everything talk. Sadly I know longer own
1993 Suburban Zombie Apocalypse Assault Vehicle (GMC Edition)
2003 Yukon Black/Charcoal cloth 4x4 POW/MIA
2003 SLE Silver/Charcoal (New Acquisition)
 Post subject: Re: Chime issue
PostPosted: Mon Aug 13, 2018 8:54 am
Year and Trim: 2004 GTO
The chime comes through the left front speaker. If the speaker is not working there will be no chime.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Mon Sep 10, 2018 10:26 pm
There is no reverse lamp/backup feed into the factory radio. My best guess is that a previous owner added it, perhaps to use with a head unit that they took out before selling the car. I've done extensive work with the wiring in these cars, including the instrument panel wiring harness and audio system. I have never found this signal on any Bonneville I've ever worked on.
There are no new unread posts for this topic. Oil Pressure Warning message and chime
Cindylou1960
Sun Jan 11, 2015 11:21 pm
There are no new unread posts for this topic. rac issue
wast3dd3ath
Thu Oct 22, 2015 8:28 pm
ddalder View the latest post
There are no new unread posts for this topic. Common issue?
BeeVeeSE1998
Tue Feb 04, 2014 8:11 am
BeeVeeSE1998 View the latest post
There are no new unread posts for this topic. PAC SWIX Issue
SSEiMan01
Thu Sep 05, 2013 8:12 pm
There are no new unread posts for this topic. CD changer issue
Mark Fahey
Sun Nov 02, 2008 2:02 pm
Mark Fahey View the latest post
