It is currently Tue Mar 19, 2019 3:03 pm
PostPosted: Wed Jul 18, 2018 11:23 pm
My current head unit doesn't recognize CDs when they're inserted, its always saying "check cd", even if it's brand new.
And then the other day it hit me that I happen to have a couple extra Pontiac head units lying around (GrandPrix and Firebird style), and I was wondering if its possible to swap the CD drives.
I successfully did this several years back, but they were both Grand Prix units.
So I'm hoping someone may have some pics of a drive out of a Bonneville head unit so I can compare them.
Or even better if someone knows if they're compatible.
Thanks in advance guys.
Drew
Pontiac stable:
2005 Bonneville GXP - Black -daily driver
2004 Sunfire - Arrival Blue Metallic -Wife's
1998 Grand Prix GT - Black -seen better days, awaiting fate
1985 Fiero Sport Coupe - Black (mostly) - long term rebuild
PostPosted: Thu Jul 19, 2018 9:02 am
Unfortunately only a Bonneville one will work. The Bonneville used a proprietary connector called a Dock-N-Lock, nothing else will work.
I have many good used radios if you're interested, but they must be programmed with a Tech2 scantool or similar.
-Andrew-
PostPosted: Thu Jul 19, 2018 8:00 pm
I read this as meaning, can he change the mechanism inside the head unit? Personally, I don't know for sure. Many of the radios seem similar so it may be possible. But, I had some GM radios that appeared to be identical however the part numbers for some internal components were different and were not interchangeable.
PostPosted: Fri Jul 20, 2018 10:34 pm
This was my experience with an '00 and '02 Bose.
http://www.pontiacbonnevilleclub.com/forum/post117813.html#p117813
I found another '02 head unit, swapped the internal CDs and it worked fine.
To save the Tech2 charge you can see if Andrew has a head unit from a Bonneville close to yours and swap the CD into yours.
Dealer Tech2 charges these days can far exceed the cost of the head unit.
PostPosted: Sun Jul 22, 2018 3:28 am
Yes, the actual mechanism is what I was asking about.
But after looking at Roadrunner's thread, I'm going to have to assume that my '05 is more like the '02 then the '00 style.
On top of that, my drive has a 14 pin connector, so it wouldn't match with either the '00 or the '02.
So probably not my '05 either.
Thanks for the responses guys!
Not what I wanted to hear, but what I needed to.
Drew
Pontiac stable:
PostPosted: Mon Jul 23, 2018 6:40 pm
maybe you can bail on the head and go for the 5 disk changer in trunk
PostPosted: Tue Jul 24, 2018 8:44 am
Year and Trim: 95 SSEi
05 GXP
I replaced just the CD drive in my 2004 Tahoe and it worked fine.
I purchased it from replacementradios.com.
Unfortunately they don't have one for the GXP, as I need one myself.
So if you can find one somewhere, but I think it needs to be the
exact unit, as I had to transfer some wiring and stuff from my old
drive to the replacement.
You could buy the whole unit from Andrew and just swap the CD drive to
avoid the dealer trip and charge.
Black 95 SSEi (original owner) 236K miles
Black 05 GXP (some idiot put the first 12K on it)165K miles
Black 04 Tahoe (original owner)284K miles
Black 16 Traverse (original owner)48K miles
Black 15 Lacrosse (some nice lady put first 15K on it)16K miles
PostPosted: Wed Jul 25, 2018 11:29 pm
I actually have a disc changer and I love it (save for the fact that it hates bumps and loves to skip, if anyone has thoughts on how to eliminate or just soften this, I'm all ears), but a lot of it just comes down to the convince of not having to pop my trunk t ok change/ add a new disc (ie, me being lazy)
Drew
Pontiac stable:
There are no new unread posts for this topic. 99 Stock HU in a 90 LE?
crzydmnd72
Sun Jul 13, 2008 1:18 am
shortstuf212559 View the latest post
There are no new unread posts for this topic. Stock Radio
NightHound
Sat Apr 07, 2012 12:14 am
NightHound View the latest post
There are no new unread posts for this topic. Attachment(s) Which stock radio do I have?
Junior28
17
1568
Thu Sep 04, 2014 11:16 pm
bobgto65 View the latest post
There are no new unread posts for this topic. AMP TO STOCK HEADUNIT
Bensbonneville
Sun Mar 11, 2012 11:43 pm
Bugsi View the latest post
There are no new unread posts for this topic. Stock or Aftermarket?
irish91983
Tue Feb 22, 2011 9:40 pm
irish91983 View the latest post
