It is currently Tue Feb 11, 2025 11:13 am
PostPosted: Wed Aug 12, 2015 11:17 pm
Year and Trim: 1997 Pontiac Bonneville SSE
Hello all I thought it'd be as easy as any other vehicle. However apparently since I have the bose amp under the dash I may run into issues.
Can someone please explain to me what issues I will run into while trying to upgrade my stock HU?
Normally I'd just order a vehicle aftermarket harness and the stereo. But apparently it's different on this vehicle because of the BOSE amp and the steering wheel audio controls.
Any help is greatly appreciated!
btw I have tried to search on this subforum but didn't want to revive any old threads specially since they were for the 2000 model.
PostPosted: Tue Sep 01, 2015 12:34 am
05 Mercedes S500 4Matic
Let's try to narrow down what you're wanting to do. In the subject you say you want to *replace* your stock Head Unit. In the post you say you want to *upgrade* your stock head unit. Tell us what, specifically, you're wanting to put IN your car. I'm guessing you want to put in a more or less common aftermarket head unit, but it isn't clear if you're wanting to replace your stock head unit with another stock head unit, or what.
Then, are you *JUST* wanting to replace the head unit? The Bose system's amp is designed to drive the Bose speakers, and aren't likely to drive aftermarket speakers well. Are you also planning to replace your speakers and use aftermarket amplifiers; or are you hoping to use your stock speakers with their Bose amp? (And if so, what are you wanting to gain by replacing your stock head unit with an aftermarket one? Are you just wanting something like a USB input, or are you wanting something else? Give us an idea of what you're specifically wanting to do, and if possible, WHY.
`05 Mercedes S500
There are no new unread posts for this topic. Wanting to install subs to the stock stereo system
Bonne&Kidd
Sat Oct 13, 2012 4:05 pm
andrewsowinski21 View the latest post
There are no new unread posts for this topic. Stock Bose 6x9's...question about upgrading
FasGP
Fri Dec 30, 2011 3:27 am
gxp-hawkeye View the latest post
There are no new unread posts for this topic. Replaced stock (Bose?) with GXP (Monsoon?)
xyeLz
Mon Mar 10, 2014 9:10 pm
There are no new unread posts for this topic. 1997 BOSE questions
sandrock
Sun Nov 30, 2008 2:31 pm
1337ssei View the latest post
There are no new unread posts for this topic. How to bypass 1997-1999 Bose Amp
matt97ssei
Mon Jan 18, 2016 9:10 am
BLinX24 View the latest post
