It is currently Sun Dec 05, 2021 1:34 pm
PostPosted: Tue Sep 24, 2013 7:59 pm
Year and Trim: 2000 SE
I was wondering if this could just be an easy remove and replace or it would require a lot of coding and splicing and whatnot?
The Southie Bullet-2000 Bonneville SE, Tinted windows, Pioneer 6 speaker sound, charcoal black leather interior, custom black side mirrors, Pirelli P-Zero tires
PostPosted: Thu Sep 26, 2013 3:53 pm
They will swap no problem, however you'd need a Tech2 to reprogram the new head unit to work with your car. Unless you someone with that scanner, you'd need to go to the dealer.
"Penelope" - 2003 SLE - 226k Miles
"Sydney" - 2000 Honda S2000 - 88k miles
PostPosted: Fri Sep 27, 2013 11:09 pm
2004 Bonneville GXP
The 2000-01 SSEi unit is designed for the Bose Amplified system and your car likely does not have the Bose system. You can tell because there are 8 speakers. So the Head Unit may not be compatible with your car. the 2002+ used a HU compatible with the Monsoon system. Is there something wrong with your head unit?
bobgto65
PostPosted: Sat Sep 28, 2013 7:45 pm
Year and Trim: 96 SSEI
Id just go aftermarket if I were you. You don't have to go through all the coding, and the harnesses probably will not link up. Like said before me, SSEI Bonnevilles have Bose systems. SE Bonnevilles usually do not. Also, aftermarket (depending on the brand) will make your speakers sound like 3x better.
1996 Bonneville SSEI "MeanGreen BonneB" - 121k Miles
PostPosted: Mon Sep 30, 2013 8:38 pm
^thanks dude! What brand do you recommend? i'd prefer something with a red backlight to match the rest of the interior lighting.
PostPosted: Mon Sep 30, 2013 9:38 pm
2004 Bonneville GXP
What is wrong with your original radio?
bobgto65
There are no new unread posts for this topic. 2000 ssei stock head unit repair
TRMN8R
Mon Nov 09, 2020 2:31 pm
TRMN8R View the latest post
There are no new unread posts for this topic. Replace Head unit with monsoon amp
Giangrande99
Thu Dec 15, 2016 1:49 am
ddalder View the latest post
There are no new unread posts for this topic. inside the 2000+ head unit
Thu Nov 20, 2008 7:10 pm
There are no new unread posts for this topic. Can u recommend an easy & practical head unit for our 2000?
STAGE III
Sun Jul 14, 2013 1:03 am
bobgto65 View the latest post
There are no new unread posts for this topic. 98 Monte Carlo Head Unit Swap into 98 Bonneville SSEi?
chargerbr549
Fri Feb 18, 2011 12:28 am
sandrock View the latest post
