It is currently Tue Apr 16, 2024 12:39 am
PostPosted: Fri Jul 19, 2013 2:35 am
Year and Trim: 2001 bonneville ssie
My entire radio headset went out it won't work after I took it out to check out the harness connections. i put it back and no luck, I'm sure it's the fuse, I would like to get it replaced but I don't know which one to pull.. Is it the fuse box under the good or under the back seat?
PostPosted: Fri Jul 19, 2013 11:32 pm
2004 Bonneville GXP
The fuse is in the fuse block under the back seat. Just lift the seat bottom up and remove the cover to the fuse block. There is a key inside the cover to show you which fuse to repalce. There is a fuse puller on the fuse block and spare fuses are located in one of the slots where the large fuses are.
bobgto65
There are no new unread posts for this topic. Aftermarket Radio - Power by Fuse?
JHMinniBoni
Thu Apr 10, 2014 10:25 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Replacing stock radio with a radio from a newer Bonneville
SuperHbody
Sun Dec 22, 2013 12:43 am
human View the latest post
There are no new unread posts for this topic. Radio Display out But Radio works
vassei
Thu Jan 22, 2015 9:51 am
There are no new unread posts for this topic. Did I fry my amp? or is it just a fuse?
sepenator
29
5910
Wed Apr 07, 2010 12:06 pm
psburtis View the latest post
There are no new unread posts for this topic. what size fuse do i need
samples08
Sat Oct 11, 2014 12:50 pm
samples08 View the latest post
