It is currently Tue Jan 22, 2019 8:29 am
PostPosted: Sun Jan 13, 2013 8:08 pm
Year and Trim: 2002 Bonneville SSEI
id like to replace my outdated factory headunit with an aftermarket eclipse CD8445. but i would like to retain the steering controls. dings etc. i want it done the right way you know? i know ill need the GMOS 09. and the PACSWIX adapter.. is there anything else i will need or is that all the wiring harness required? i dont know how either is set up. but im getting my cousin to hook it up and i want to have all of the wires and everything ready when i take the car to him. thanks alot for any help. if it matters. ill be hooking up cdt 6.5 door speakers in the front on an elemental designs amp. disconnecting the rear 4 speakers and using a 15 inch soundsplinter sub on 1000w memphis amp
PostPosted: Mon Jan 14, 2013 7:11 pm
Year and Trim: 2000 SSEI
that should get the deck in. Again you need to trim behind the radio (in most cases), Be carfull not to damage the wires behind there. i used a Dremmel and a wide flat head screwdriver and chizzled it out with a hammer once all the wires were cleared out of the way. I used a Metra steering wheel adapter.. it will need to be manually programmed to make the buttons all work exactly like stock but the auto learn will get most of them correct.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Tue Jan 15, 2013 10:02 pm
05 Mercedes S500 4Matic
This thread should have all the information you need:
http://www.pontiacbonnevilleclub.com/forum/audio-and-aftermarket-electronics/topic7319.html
`05 Mercedes S500
There are no new unread posts for this topic. Aftermarket Headunit - '03 SE
do9105
Thu Apr 23, 2009 1:15 pm
SAMzGXP View the latest post
There are no new unread posts for this topic. Factory headunit from 05 Sierra work?
DOMESTICated
Wed Oct 14, 2015 7:51 pm
DOMESTICated View the latest post
There are no new unread posts for this topic. Replacing factory with GXP
xyeLz
Wed Feb 26, 2014 11:46 pm
bobgto65 View the latest post
There are no new unread posts for this topic. Using factory XM antennae with aftermarket HU
05joenov
Mon Aug 01, 2011 7:20 am
05joenov View the latest post
There are no new unread posts for this topic. Replacing factory speakers
PLAGUE PHANTOM
Tue Apr 12, 2011 9:55 am
willwren View the latest post
Users browsing this forum: Exabot [Bot] and 3 guests
