It is currently Tue Feb 19, 2019 6:37 pm
 Post subject: 92-99 Aftermarket HU
PostPosted: Tue Nov 20, 2012 12:41 am
Year and Trim: 1999 Pontiac Bonneville SE
1997 Pontiac Firebird
I know there has been previous postings but I didn't get the straight forward answers I wanted. I had a few questions about installation and what I will need. What has worked for others as far as an installation kit/mounting kit as well as wiring harness or any other parts. Will there be any sacrifices or roadblocks?
1999 Pontiac Bonneville SE- Stored -All stock, Sony CDX-GT570UP HU w/ Scosche HD 6.5"'s front/Alpine S 6x9 rear, 153,000 miles
1996 Pontiac Bonneville SE- Now a parts car - HAI, Muffler Delete, Summit Y-pipe, 250,000 miles
1997 Pontiac Firebird - DD - 3800 Series II, Cold air intake/FWI, Y87 Package, Sony DSX-S100 Digital Media Reciever, 180,000 miles
 Post subject: Re: 92-99 Aftermarket HU
PostPosted: Tue Nov 20, 2012 3:46 am
05 Mercedes S500 4Matic
The most common replacement aftermarket HU's are single-din, so you need a dash kit. I recommend this one:
http://www.metraonline.com/part/99-4000 which uses the extra half din space for a cd pocket underneath the HU. Wiring harness adapters are easy for these cars, they're fairly common and standard. There are a couple 1.5 Din units out there, but I don't recommend them, as they don't update them very often to add modern expected features.
If you're going to add an amp in your trunk, you'll want to run a power cable from the battery to the trunk. There's a guide here with pictures for where to drill through the firewall to pass a power cable through. You'll also need to run line-level cables to the amp from the head unit, which is a good time to run new speaker wires, too.
If you have steering wheel controls for your radio there are adapters to keep their function. The PAC-SWI is the one most have had success with. If you have the heads-up unit, you'll lose the radio display on that. If you have the Bose unit you have to decide whether to keep the Bose amp and speakers or replace everything.
`05 Mercedes S500
PostPosted: Tue Nov 20, 2012 5:04 pm
Wow, thank you. Will order the Metra 99-4000 kit. the PAC-SWI is out of my budget right now so I can live without the wheel controls. It is cool they have an item for that though for future reference.
PostPosted: Fri Nov 23, 2012 1:47 am
Year and Trim: '98 LSS L67
I have been slowly foraging components for my system as well, and I'm getting there, but isn't there also an adapter for the door/lights/fuel/key chime? It's not as necessary in the LSS as it has been in some of my older Bonnies, since it has the auto power cutoff if a drain is detected (neat) and the inability to lock keys inside when they're in the ignition, but still valuable IMHO.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
PostPosted: Fri Nov 23, 2012 5:52 am
For the year being discussed in this post, these functions do not go through the radio harness.
`05 Mercedes S500
There are no new unread posts for this topic. Aftermarket
kc9dre
Sun Nov 12, 2017 9:27 pm
kc9dre View the latest post
There are no new unread posts for this topic. no sound aftermarket hu
mfcordova2008
Tue Apr 19, 2011 8:30 am
05joenov View the latest post
There are no new unread posts for this topic. aftermarket stereo
PossessedPower
Sun Feb 27, 2011 2:44 pm
willwren View the latest post
There are no new unread posts for this topic. Aftermarket Gauges
Shae
Fri Feb 18, 2011 4:25 pm
There are no new unread posts for this topic. Stock or Aftermarket?
irish91983
Tue Feb 22, 2011 9:40 pm
irish91983 View the latest post
