It is currently Sun Feb 17, 2019 8:31 am
PostPosted: Mon Jul 25, 2011 3:53 pm
Year and Trim: 1995 Bonnieville SE
Hello to all,
Newbie here...thanks in advance for info.
The radio controls on my 95 bonnie do not work the radio at all. Where should I start with this? The radio works fine...just not from the wheel.
Thanks,
Scott
PostPosted: Mon Jul 25, 2011 4:06 pm
Hi, I had this happen on my 92 GTP and it was the wires in the steering column. I guess with all the turning of the steering wheel the wires get messed up. I even could see little puffs of smoke coming from the column. This could be the problem. I didnt get it fixed because it was too much of a hassle and the car was over 330K.
Try turning the wheel at different points and see if you get anything. Do the buttons lights work or are they dark?
PostPosted: Mon Jul 25, 2011 6:17 pm
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
There is a fuse at the base of the steering column. It is either that or the SIR coil (clockspring) is bad.
PostPosted: Mon Jul 25, 2011 6:35 pm
Year and Trim: 1995 SSE
Just had this exact issue on my 1995. Turns out the insides of the switches were melted. This write up explains exactly how to do the job. Took me a couple of hours and now they work perfectly.
viewtopic.php?f=49&t=1692
PostPosted: Tue Jul 26, 2011 12:59 am
kipwrite--did you use the toothpick method or the JB weld? I am guessing the toothpicks, as you say it only took a couple of hours.
Chris
PostPosted: Thu Jul 28, 2011 1:46 am
Year and Trim: 1997 SLE factory L67, stock
1992 SSEi
1990 GP SE
I had a 93 GTP I bought with 127,000 and it was the plate in the steering colomn that was all warped (the contacts ride on the plate as the steering wheel turns) Changed the plate and I had steering wheel controls again. The Bonneville may not be the same issue.
Chris
97 SLE with L67 (1 of 354!) * 90 Grand Prix SE * 1992 SSEi * 99 Buick Regal * 2006 Chevy Uplander
There are no new unread posts for this topic. Attachment(s) Steering Wheel radio controls
kipwrite
Tue Aug 02, 2011 11:51 pm
There are no new unread posts for this topic. aftermarket radio and steering wheel controls
biohazed
Thu Jan 22, 2009 4:07 pm
gatechguy View the latest post
There are no new unread posts for this topic. Newbie needs help! Steering wheel radio controls.
ktownSSEiguy
Wed Nov 19, 2008 9:48 pm
bonnevillain View the latest post
There are no new unread posts for this topic. Steering wheel radio controls don't work
human
Wed Oct 27, 2010 11:07 pm
There are no new unread posts for this topic. radio controls
bonnelover
14
2072
Tue Oct 26, 2010 11:28 am
2002BonnevilleSE View the latest post
