It is currently Wed May 21, 2025 8:16 pm
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jul 21, 2011 6:43 am
Let's make it clear, the rear 6x9s are NOT 2ohm. I have seen the amps internals there is only one output channel for the subwoofer. They are two 1ohm speakers wired in series to create a single 2ohm load.
If you would have stopped to read first you would know that.
EDIT: Tyler you have an 02, that meas you have the monsoon correct? This info thread is for the BOSE! system, you have went and posted misleading and incorrect information in two threads because you don't really know what you are talking about. The bose and monsoon are two completely different systems with different amps and speakers
Current fleet:
PostPosted: Fri Jul 22, 2011 1:12 pm
Year and Trim: 2000 SSEI
couldnt you replace the 6x9's with (2) 4 ohm speakers and wire them in parrallel you would end up with the same 2 ohms correct? that would make replacing the 6x9's easier with off the shelf speakers and still maintain the 2ohm load to keep the higher power output of the amp? I have not looked at the OEM wiring, im assuming they chain together rather then at the amp.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Jul 22, 2011 1:38 pm
Yeah, you could do that. It would be a little involved as far as the wiring went, but it would be doable.
Current fleet:
PostPosted: Wed Aug 03, 2011 9:27 pm
Year and Trim: Currently searching for a Bonneville...
swampthing wrote:
copied and rotated the wire colors to make them easier to read, any other questions feel free to ask and I will try to find the information
Woo hoo! Thanks for the pics of the amp connector, now I can figure out which one of my rear 6x9's are wired out of phase.
FWIW, I used the speaker wires that originally went to the rear 6x9's, and used them for the line converter that runs my sub amp, a Hifonics BXI1608D. I then spliced into wires that go to the Bose amp INPUT, and ran them to a separate two channel amp which drives aftermarket 3-way 6x9's. Somehow, in doing so I reversed polarity on one 6x9 (or input to the amp) so it's playing out of phase. I wish there was an easy way to tell which one without digging through amp wiring again.
Having the extra power and clarity with the 3-ways on the rear deck was a huge improvement-- The stock rear door speakers just didn't do it for me. So essentially the system is stock aside from powered 6x9's and two 12" subs in the back.
Inferno Red 2009 Dodge Caliber SRT-4 125k
PostPosted: Fri Aug 05, 2011 2:42 pm
Year and Trim: 1997 Pontiac Bonneville SSE
Would this information still apply to an '97 model? I am currently having the no sound issue with my aftermarket radio and when I read this post and what others have told me, it doesn't seem to match up with mine. Any suggestions?
PostPosted: Fri Aug 05, 2011 3:19 pm
No this information applies to 2000+ models only, start a new thread with your questions and someone with experience on the 96-99 models will help you
Current fleet:
PostPosted: Wed Aug 10, 2011 8:08 pm
swampthing wrote:
Adapters: The factory door chimes work through the stereo, if you don't care about them you can buy a cheap wiring adapter. However if you want the chimes I only know of two adapters for our cars to date and only have personal experience with one. they are the PAC C2r-GM32r and the Metra GMOS-9
I used the pac. overall it did the job however the buzzer used to replace the chimes was loud and annoying and I eventually taped over it anyways.
This brings up another very common problem, You installed the radio but have no sound, this is because the BOSE amp is not getting a turn on signal from the radio you simply have to run a wire from the blue/white wire on the cd player harness to this pink wire on the BOSE amp
and you are done
with the Metra you may not have to do this, perhaps someone with experience could chime in?
I did install a Kenwood DDX512 HU and i used the metra dashkit (decent), Metra GMOS-9, Metra ASWIC (steering wheel controls) and the VW10 antenna adaptor. I clipped 1 wire in the GMOS9 as indicated on the wire and the instructions which was for the 00-01 bose system. the ASWIC worked pretty good. couple buttons are not doing the correct functions but can be manually reprogramed per the instructions (had some trouble doing so, so i gave up) I didnt do the onstar instructions so my onstar is inop (no sound atleast, and i don't plan on using it). everything seems to be pretty straight forward but was a PITA comparied to most installs do to the cutting of the rear dash behind the deck. all said i got all the metra parts for $150 shipped on amazon. The Amp turned on and powered up the speakers perfectly on the 1st try, so no funny amp wiring to the bose amp with the metra harness.
Shane "RedZMonte"
PostPosted: Wed Aug 10, 2011 8:20 pm
thanks for the info! I will add it to the main information page for better visibility
Current fleet:
PostPosted: Thu Aug 25, 2011 6:05 pm
Glad i read this thread before making my purchase.
I have an 02 SSEi w/ 8 speaker bose i just replaced head unit with pioneer simply cuz the CD did not work on the Bose nor does the 12 disk changer in the trunk.
Here is my reason for posting...
I seem to have a blown (factory) 6x9 it makes loud popping sound at very high volume with heavy base. I check the speakers with an ohm meter and it reads 2.0 so i found nice infinity kappas 2 ohm that i was about to purchase but i thought i would check here before doing so. Now that i have read that the originals are actually 1 ohm does anyone have a cheap solution? Maybe someone upgraded there system and has there old originals collecting dust? I cant see spending $100.00 for 1 stock speaker http://mnrelectronics.com/delbos6x9spe.html
Another thought i had was... does anyone make a low watt (35) Subwoofer in an enclosure that i could just plug into instead of the factory speakers?
i'm open to suggestions :thumbup:
Disabled DRL's. Cleared the front turn signals lights. Infinity Kappas all around. Stainless. up swept quad exhaust tips. 180 T-stat, autolite 104's. 42k miles on motor with new LIM. 80k on car
PostPosted: Thu Aug 25, 2011 6:19 pm
Are you sure you have Bose? 02 has the monsoon if I am not mistaken
Current fleet:
PostPosted: Thu Aug 25, 2011 6:48 pm
Bose 100% sure on that
PostPosted: Thu Aug 25, 2011 9:10 pm
I'm 90% sure you should have Monsoon. Crawl in the trunk, remove the plastic cover from the backseat (Just held on with magnets) and the amp will say "MONSOON" if that's what you have. Not sure whether the Bose amp is marked or not.
PostPosted: Thu Aug 25, 2011 9:54 pm
Bose amp isn't marked. It's behind that plastic cowl in the trunk nearest the rear seats, it's black, about 6 x 8", and the outside is also the heatsink (has fins) like most amps.
PostPosted: Thu Aug 25, 2011 10:27 pm
Does it matter weather its monsoon or bose? the ohm meter reads 2 ohm. The factory head unit clearly says Bose and the car is not here at the moment.
PostPosted: Thu Aug 25, 2011 10:50 pm
Yeah it does, did you disconnect the wires from the speaker when you tested the impedance?
Current fleet:
PostPosted: Thu Aug 25, 2011 10:51 pm
There really isn't an aftermarket 2 ohm speaker available that I know of. Some will advertise 2 ohms, but that's at a given frequency. Most often they're actually quite higher than that, such that they can still be compatible with 4 ohm amps (nearly all car amps are 4 ohm rated / channel). No manufacturer would make a speaker whose load is actually 2 ohms, because it would not work or be marketable toward 99% of stock car stereos.
On my 2000 Bose system: The bose amp for the rear speakers is single channel. From what I measured, the two 2 ohm speakers in the back are wired in series for a 4 ohm load at the amp.
PostPosted: Thu Aug 25, 2011 10:55 pm
the wires were connected to the speakers and stereo was on when i tested
PostPosted: Thu Aug 25, 2011 10:56 pm
Test only with the speakers disconnected!
PostPosted: Thu Aug 25, 2011 11:06 pm
testing again is not that simple. ohm meter was borrowed. Did they use monsoon amps with bose head units in 2002?
PostPosted: Thu Aug 25, 2011 11:07 pm
Jedwards, that cannot be the case with the bose, when I replaced my stock rear 6x9s I used infinity speakers thinking that I would keep the correct impedance, but it didn't. My sound was cut in half, and when I disconnected one speaker, effectively making the load 2ohm . The single speaker that was connected got louder
Current fleet:
There are no new unread posts for this topic. Bose Audio
KelvinVV
21
4017
Mon Sep 09, 2013 5:28 pm
maroon111993 View the latest post
There are no new unread posts for this topic. Speakers w/ bose audio...
Raviaan
Mon Aug 18, 2008 6:27 pm
lglarum View the latest post
There are no new unread posts for this topic. Factory audio bose for my 2001
seekinhighhp
Mon Nov 29, 2010 9:54 pm
There are no new unread posts for this topic. 1997 BOSE questions
sandrock
Sun Nov 30, 2008 2:31 pm
1337ssei View the latest post
There are no new unread posts for this topic. 1993 Bose questions
i<3bonbons
Tue May 19, 2009 5:26 pm
alec_b View the latest post
