It is currently Wed Oct 05, 2022 4:40 am
PostPosted: Sat Jun 12, 2010 5:29 pm
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
This is the 97 SE. The display on the radio was acting funny for awhile sometimes when you would first start up the car it wouldn't come on for a while and then it would pop on. And sometimes the numbers would be all scrambling and now it just stoppe workin all together
Anyone know what the problem is?
Checked the fuses an they are fine.
It's weird too bc sometimes when the sun will shine on a certain angle I can read the display but it's like the backlight is no working or something?
oh BTW this is the stock radio unit is there some bulbs or something?
Could I just take it apart and figure it out?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Sun Jun 13, 2010 1:09 pm
68 w/400
94 SSEi
Anyone?
Clay
PostPosted: Mon Jun 14, 2010 3:51 pm
Year and Trim: 2003 SLE || 51k miles
I'd give it a bit more than 18 hours.....
-Mike
PostPosted: Wed Jun 16, 2010 8:10 pm
68 w/400
94 SSEi
Idk. Now I hit the recall button today and it started working again.
Idk. What's going on?
Clay
PostPosted: Wed Jun 16, 2010 8:11 pm
Year and Trim: 2004 Volvo S60
Intermittent connection. When my dash was pulled,the radio had one light out. I took the radio back out again for another dash pull because my mechanic had to fix a crack in the dash he made, and since it's been put back in, it's worked without flaw. You are probably looking at something similar...
PostPosted: Wed Jun 16, 2010 10:13 pm
68 w/400
94 SSEi
So just taking it out and putting it back in may fix it?
Clay
PostPosted: Wed Jun 16, 2010 10:33 pm
Can't say it'll work for you, was just what happened in my case.
PostPosted: Mon Aug 30, 2010 1:07 am
Year and Trim: 1996 SE
The bulb that backlights the radio display is soldered to the circuit board inside the radio. Over time, it breaks loose. For a while you will have intermittent backlighting, then eventually none. The fix is to resolder the bulb. Or get an aftermarket stereo.
PostPosted: Mon Aug 30, 2010 5:39 am
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
If it has never been opened or fixed before, the bulb assembly screws onto the pcb. They actually weld themselves together over time.
I have replaced the factory bulb with these
PostPosted: Mon Aug 30, 2010 7:15 am
68 w/400
94 SSEi
Ok thanks. That's one more thing one the to do list.
I have been having less and less radio display lately. I'm wondering if it went out altogether not because it hasn't worked for about 2 weeks. Usually it comes on and off every couple days.
Clay
There are no new unread posts for this topic. Radio Display out But Radio works
vassei
Thu Jan 22, 2015 9:51 am
robjr69
14
3244
Sat Jan 15, 2011 2:22 pm
robjr69 View the latest post
There are no new unread posts for this topic. 97 Ei Blank Radio Display
Maymybonneliveforevr
Sat Mar 20, 2010 6:03 pm
There are no new unread posts for this topic. Radio has display but no sound
diamondlovr
Sun Jan 16, 2011 11:37 pm
There are no new unread posts for this topic. 97 SSE radio/CD no equalizer no display backlighting
dottie62
Thu Apr 28, 2011 11:21 pm
cron
